| Guest | xp - catch system events Idle + Lockdown Hi all I would like to run my app (C# 3.0 Win application) on the following XP pro/home events: Enter and exit idle mode (peripherals don't get input for few minutes) Station lockdown and entrance (winkey + L or alt+ctrl+del -> lock computer) I can create windows C# service that periodically check (if its possible) the different situations, but I don’t want to add load to the station. Please advice, Sharon |
| unable to catch WordApplication events on vista32 using Wod 2007 | VB Script | |||
| System Freezes after being idle | General Discussion | |||
| System freezes after being idle!! | Vista performance & maintenance | |||
| CPU 50% System idle shows 98% | Vista performance & maintenance | |||
| system busy when idle | Vista General | |||
