| Guest | Not possible to make shortcut to filename.scr with switches? I have been programming a screensaver, and I have made an installer for it which makes some shortcuts in the start menu. But I have found a problem, and it doesnt make sense, and I have no idea what to do about it: When I try to make a shortcut to "filename.scr /c", and then run it, windows switches the /c with a /S. which means the screensaver will start, instead of showing its configuration. Any idea of what to do about that?? I could make a batchfile or something, but I feel that would just be cheating and not a real fix... |
| Is it possible to make a tutorial for "shortcut to clear undo/redo in explorer"? | General Discussion | |||
| Cannot make a shortcut... | Vista General | |||
| how to make a shortcut to lock computer and activate screen saver | General Discussion | |||
| get-date - make it a filename | PowerShell | |||
| Re: How do I make a shortcut run an program in "current directory" | Vista account administration | |||
