Go Back   Vista Forums > Misc Newsgroups > WinFX General
Vista - OneNote Mobile does not work
Old 09-23-2007   #1 (permalink)
DiscipleTom
I getting pretty frustrated...I've installed OneNote Mobile...initially it
worked...however, I needed to flash the ROM on the PDA (an ATT 8525) and
after I did that and reinstalled ON, it would not transfer files. Since then,
I've removed the OneNote program, Checked the Regedit to make sure there was
no references to it...reinstalled and still it won't work. What can I do??
What am I missing?? Is there some fragment of the initial install that is
remaining on my system that is screwing me up?? I don't know where else to
turn for help.
I am using OneNote 2007, Vista on the PC, and WM5 on the PDA and Windows
Mobile to transfer the files. I am also using the John Guin's PowerToy.
Thanks in advance for any help that you can give me.
Windows Mobile 6.5 UI a big improvement; more work needed Vista News
Minimizing OneNote on startup, Can Microsoft Office OneNote 2007 be started minimized Microsoft Office
will windows mobile 5.0 work with sideshow Vista hardware & devices
OneNote 2007, Groove 2007 doesn't fully work on Vista 64 Vista General
Windows Mobile Device Center Does not work with OneNote Mobile Vista hardware & devices
