Go Back   Vista Forums > Misc Newsgroups > WinFX General
Vista - Install problem with Feb CTP
Old 05-17-2006   #1 (permalink)
Lydster
When trying to install the WinFX Feb CTP I'm getting a failure when it tries
to download the necessary components... The problem seems to be around
signing of assemblies being downloaded - in the error report it tries to send
off to Microsoft, the following lines appear:-
[05/17/06,14:35:06] Windows Communication Foundation Beta 2: dlmgr:
-2146762749
CheckTrust.VerifyTrust failed
Certificate_Fail: CDownloadJob::VerifySignature() : Indigo.exe is not signed
by Microsoft, and therefore is deleted.
I've slackened off my .net 2 runtime policy so that the whole world (and
their dogs) could run code on my machine but this doesn't achieve anything.
I've also been through the downloading troubleshooting steps referred to in
the help file, and configured BITS properly but to no avail.
Any ideas?
Thanks,
Steve
Old 05-17-2006   #2 (permalink)
Lydster
RE: Install problem with Feb CTP
Ok ignore that: I've found the link to download the whole install kit instead
of doing the web-based install...
http://download.microsoft.com/downlo...4A/winfxrc.exe
Steve
"Lydster" wrote:
> Hi,
> -2146762749
> Any ideas?
> Thanks,
> Steve
sp1 install problem Windows Updates
WLM Install problem Vista mail
Problem install RC2 Vista General
RC1 install problem: Disk does not meet the criteria to install vi Vista installation & setup
Yet another install problem Vista installation & setup
