Screen resolution stuck at 640
  1. #1
    Leeann Guest
    I reinstalled XP, and now my resolution is stuck at 640. I followed the HELP
    section, which says to go under Advanced in the properties setting, click
    moniters then properties. But properties isn't clickable in the monitors tab,
    so I have no idea what to do. Everything else seems to be working fine.
    Any suggestions?
  2. #2
    Travis King Guest
    Re: Screen resolution stuck at 640
    You might have better luck posting this question at
    microsoft.public.windowsxp.general.
    "Leeann" <Leeann@discussions.microsoft.com> wrote in message
    news:74837408-B0ED-44AB-81DB-A3BE0694114C@microsoft.com...
    >HELP
    > tab,
    > Any suggestions?
  3. #3
    Leeann Guest
    Thanks.
    > >HELP
    > > tab,
    > > Any suggestions?
  4. #4
    Travis King Guest
    You're welcome.
    news:B6220DB6-E486-41BA-92CD-5BD36C488246@microsoft.com...
    > Thanks.
    >> >HELP
    >> > click
    >> > monitors
    >> > tab,
    >> > Any suggestions?
  5. #5
    Zack Whittaker Guest
    Try changing your colour depth if possible - sometimes if you're on 8-bit
    colour then it can sometimes restrict you from making the resolution any
    higher. Make sure it's on 32-bit at least, apply the changes then try
    changing your res. after that.
    Zack Whittaker
    » ZackNET Enterprises: www.zacknet.co.uk
    » MSBlog on ResDev: www.msblog.org
    » Vista Knowledge Base: www.vistabase.co.uk
    » This mailing is provided "as is" with no warranties, and confers no
    rights. All opinions expressed are those of myself unless stated so, and not
    of my employer, best friend, Ghandi, my mother or my cat. Glad we cleared
    that up!
    --: Original message follows :--
    "Travis King" <Anonymous@none.com> wrote in message
    news:etwBuCieGHA.1320@TK2MSFTNGP04.phx.gbl...
    > You're welcome.
    >> Thanks.
    >>> >HELP
    >>> > click
    >>> > monitors
    >>> > tab,
    >>> > fine.
    >>> > Any suggestions?
Stuck Screen Resolution shakured Graphic cards 3 26 Aug 2009
TV Stuck at 8 bit colour depth and low resolution Daz Vista General 1 06 Jul 2006
Stuck with Safe Mode Resolution Itachi12 Vista installation & setup 0 15 Jun 2006
Resolution stuck at 640.. Leeann WinFX General 1 17 May 2006
