| | Resolution stuck at 640.. I reinstalled XP, and now my resolution is stuck at 640. I followed the HELP section, which says to go under Advanced in the properties setting, click moniters then properties. But properties isn't clickable in the monitors tab, so I have no idea what to do. Everything else seems to be working fine. > Any suggestions? |
| | Re: Resolution stuck at 640.. Did you remember to reinstall the drivers for your graphics card/chip after the Windows reinstall? -- Jane, not plain 64bit enabled ![]() Batteries not included. Braincell on vacation. "Leeann" <Leeann@discussions.microsoft.com> wrote in message news:25B3A003-4EC2-466F-BAD7-D56D9F81210E@microsoft.com... >I reinstalled XP, and now my resolution is stuck at 640. I followed the > HELP section, which says to go under Advanced in the properties setting, > click moniters then properties. But properties isn't clickable in the > monitors tab, so I have no idea what to do. Everything else seems to be > working fine. > >> Any suggestions? > > |
| Stuck Screen Resolution | Graphic cards | |||
| TV Stuck at 8 bit colour depth and low resolution | Vista General | |||
| Stuck with Safe Mode Resolution | Vista installation & setup | |||
