Go Back   Vista Forums > Misc Newsgroups > WinFX General
Vista - Build 5384 internet connection issue?
Old 05-26-2006   #1 (permalink)
ildar
Installed build 5384 on Virtual Server 2005 R2. LAN is visible but can't
browse internet via IE. Any idea?
The same with Longhorn build 5384 on the same box. Internet works fine.
Ildar
Old 05-26-2006   #2 (permalink)
Zack Whittaker
Re: Build 5384 internet connection issue?
Make sure that your DNS settings are correctly put in the IPv4 settings of
the networking device.
Zack Whittaker
» ZackNET Enterprises: www.zacknet.co.uk
» MSBlog on ResDev: www.msblog.org
» Vista Knowledge Base: www.vistabase.co.uk
» This mailing is provided "as is" with no warranties, and confers no
rights. All opinions expressed are those of myself unless stated so, and not
of my employer, best friend, Ghandi, my mother or my cat. Glad we cleared
that up!
--: Original message follows :--
"ildar" <ildar@discussions.microsoft.com> wrote in message
news:E3436B0C-C084-49A1-A535-C456B649D928@microsoft.com...
> Ildar
Old 05-26-2006   #3 (permalink)
ildar
I already checked that. They are the same as on the host machine.
Disabled IPv6 too. The issue still there.
Ildar
> Zack Whittaker
> that up!
> > Ildar
Old 05-29-2006   #4 (permalink)
Tim Majni (@Hewlett.Packard)
RE: Build 5384 internet connection issue?
Well, at least I'm not the only one with this problem. My network connection
seems to be working as from a command window I can ping my bridge (wireless
AP), gateway (wireless router), and DNS (at ISP). Not only that, but the DNS
is also resovling names to ping servers on the internet. IE works to access
HTML management pages for the AP and wireless.
I have fiddled with the network and IE configuration but nothing seems to
make IE work beyond the router...
HELP!!!
Tim Majni
> Ildar
Old 05-31-2006   #5 (permalink)
ildar
Found a solution......
Install FireFox.
That's ridiculous.
Ildar
> HELP!!!
> Tim Majni
> > Ildar
Old 06-22-2006   #6 (permalink)
c_hr1s
RE: Found a solution......
I can connect to the internet and join my domain, I can surf no problem but
under Network Center there is no connection to the internet. I get a "Windows
cannot find "www.microsoft.com" using DNS" error. Yet I have activated my
Beta online and now I cannot activate my Office 2007 online as it says
there's no Internet Connection. Any ideas? My DNS is resolving all my names
and all network activity is normal!!
"ildar" wrote:
> Install FireFox.
> That's ridiculous.
> Ildar
> > HELP!!!
> > Tim Majni
> > > Ildar
Internet connection issue Network & Sharing
I need help with internet connection issue Browsers & Mail
RC1 on build 5384 Vista installation & setup
Vista public build 5384, nerds build 5472 Vista General
Vista build 5384 Internet not connected Vista networking & sharing
