| | Problem in DeSerialize a VB3 binary object to VB.Net Hi, I have a VB3 object which struct like this: Type MyType IntegerA as Integer IntegerB as Integer End Type That object has been serialized to be a "MyType.dat" from the VB3 app. Now I am rewriting that app to be a .Net application. I try to deserialize the "MyType.dat" object by the following code: ... My .net Struc like this Public Structure MyType Public IntegerA as Integer Public IntegerB as Integer End Structure ... function is like this Dim stream As FileStream stream = New FileStream(path, FileMode.Open) Dim formatter As New BinaryFormatter Dim type As MyType type = DirectCast(formatter.Deserialize(stream), Terminal) I got an error when direct cast. ... Error as follow Binary stream does not contain a valid BinaryHeader, 32 possible causes ... Please tell me can it be done or what did I done wrong. -- Thanks, Gary http://blogs.wdevs.com/garylam/ |
| Entry point and binary problem, HAVE JAVA!! | Software | |||
| deserialize objects via import-clixml | PowerShell | |||
| How to embed manifest in TCL binary? - mt.exe corrupting my binary | Vista General | |||
| The binary form of an ACE object is invalid | PowerShell | |||
