Go Back   Vista Forums > Misc Newsgroups > WinFX General
Vista - Remote desktop.
Old 06-30-2006   #1 (permalink)
Kevin Burton
Remote desktop.
I have setup a VPN connection under Vista/Longhorn. The connection indicates
success (when I click on the "connect" button). However when I use remote
desktop to connect to a computer that is in the remote domain I get an
indication that the computer could not be found. How can I diagnose this? If
I do something similar in Windows 2003 it works just fine so I know the
remote network and computer is OK. It just seems that with Vista/Longhorn I
am unable to connect.
Any ideas?
Thank you.
Kevin
Old 06-30-2006   #2 (permalink)
Kevin Burton
RE: Remote desktop.
Does this help? This is after I do a VPN connection.
Microsoft Windows [Version 6.0.5384]
(C) Copyright 1985-2005 Microsoft Corp.
ipconfig /all
Windows IP Configuration
Host Name . . . . . . . . . . . . : BURTON
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
DNS Suffix Search List. . . . . . : Belkin
Ethernet adapter Local Area Connection 5:
Connection-specific DNS Suffix . : Belkin
Description . . . . . . . . . . . : Realtek RTL8169/8110 Family Gigabit
Ether
net NIC
Physical Address. . . . . . . . . : 00-11-09-8A-7B-85
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
Link-local IPv6 Address . . . . . : fe80::8a5:dd00:95f4:846%10(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.2.6(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Lease Obtained. . . . . . . . . . : Friday, June 30, 2006 6:52:55 PM
Lease Expires . . . . . . . . . . : Monday, July 09, 2040 8:29:58 AM
Default Gateway . . . . . . . . . : 192.168.2.1
DHCP Server . . . . . . . . . . . : 192.168.2.1
DNS Servers . . . . . . . . . . . : 192.168.2.1
NetBIOS over Tcpip. . . . . . . . : Enabled
Tunnel adapter Local Area Connection* 4:
Media State . . . . . . . . . . . : Media disconnected
Description . . . . . . . . . . . : Teredo Tunneling Pseudo-Interface
Physical Address. . . . . . . . . : 02-00-54-55-4E-01
DHCP Enabled. . . . . . . . . . . : No
PPP adapter Work:
Description . . . . . . . . . . . : Work
IPv4 Address. . . . . . . . . . . : 172.16.5.4(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.255
Default Gateway . . . . . . . . . : 0.0.0.0
DNS Servers . . . . . . . . . . . : 172.16.1.1
172.16.1.2
Tunnel adapter Local Area Connection* 5:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter
Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
Link-local IPv6 Address . . . . . : fe80::5efe:172.16.5.4%17(Preferred)
NetBIOS over Tcpip. . . . . . . . : Disabled
Tunnel adapter Local Area Connection* 7:
Description . . . . . . . . . . . : isatap.Belkin
Link-local IPv6 Address . . . . . : fe80::5efe:192.168.2.6%11(Preferred)
> Any ideas?
> Thank you.
> Kevin
Remote desktop can not find remote computer Network & Sharing
Can't login to remote comp. using Remote Desktop Connection on Vis Vista account administration
Remote Desktop problem with remote printers Vista networking & sharing
remote desktop connection? AKA remote access? Vista General
Remote Desktop - Able to have one user logged in locally and one user via remote desktop? Vista networking & sharing
