Booting Problems Help Plz
Kroenne
So about 15 minutes ago my parents called me with some computer issues that are definitely out of my realm.
Every time my parents go to boot up their computer they are receiving a message that says there was a problem encountered when trying to boot up. Then it takes them to a screen that says the system will auto fix itself. However, it fails to do so. It then reads the generic send issue, or don't send. It also gave a tip to unplug any USB device that could have possibly just been installed. So I had them unplug everything with the exception of the keyboard and mouse and the problem persists. I was able to guide them through advanced options to see what the problem was more specifically, and apparently they are getting the message:
Boot Critical File C:\CI.dll is corrupt.
I myself have not had any luck finding a solution here or after searching the internet. I tried to have them boot in safe mode but the problem persists. Anyone have ideas or work arounds that can help with the situation? The only bit that I thought would work clearly did not ha.
Thanks in advanced,
Kyle
Hi welcome to the forum.
Sorry that your having some problems with your parents computer.
I think we need a little more on the specs, OS32 does not tell us very much, the more info we have the better.
If that is possible. Now, you say they did a boot in safe mode ?
If it was the one in the link below, please return & we will continue with something else.
If it was NOT this one, please click on the link, and follow the clear instructions.
Then report back OK? Link:-
How to troubleshoot a problem by performing a clean boot in Windows Vista or in Windows 7
Thank you.
    Hewlett-Packard SR5019UK
    M2N68-LA (Narra)
    2.50GB
    nVidia GeForce
    Realtec ALC888 Audio
    17" LCD Monitor
    160 Gb Usable Hard Drive
Thank you for the reply. I will have to drive over there tomorrow to get more detailed information of their specs. I do not live with them and its 11:30 so they will be asleep. Ill take my laptop with me tomorrow.
Hey that's fine.
Just check it out with your parents computer, then contact the forum fir more instructions if you need to.
Please let us know how you progress.
Thank you.
    M2N68-LA (Narra)
    2.50GB
    nVidia GeForce
    17" LCD Monitor
