Help me!!! no ethernet driver installed
albumleaf
Help!!!
I have Changed my vista computer back to xp because it was to slow.
There are no drivers installed so i can't use the internet. so i use a laptop.
I tried to find the drivers for the computer of certain modile but said that they
only had drivers for that computer for vista only.
What do i do???
Hello albumleaf,
welcome to the vista Forums:party::party::party:;)
Make sure you read the Forum Rules so you don't get into Trouble.
Could you please post The model and name of you computer.
Sam
    Toshiba Satellite Pro l300
    Intel(R) Celeron(R) CPU 550 @ 2.00GHz
    Intel Corp. 88395664Q
    DDR2, PC2-5300 (333 MHz), 1024 MBytes, Hyundai Electronics,DDR2, PC2-5300 (333 MHz), 2048 MBytes, Ap
    Realtek HD Audio
    Matte screen
    1024 x 768 x 4294967296 colors
    120gb SATA 2.5inch FUJITSU MHZ2120BH G1 ATA Device
    Notebook
    Fan cooled
    Logitech Cordless Desktop EX110
    Logitech Cordless Optical
    256Kbps
    I like Spore,Rabbits and I'm a Computer Freak.
    Realtek HD Audio
    Matte screen
    Notebook
    Fan cooled
    256Kbps
1 Click the Windows Start Button, and then click Control Panel.
2 Click Hardware and Sound.
3 Double-click Phone and Modem Options.
4 Select the Modems tab, and then click the Properties button.
Then find out what model you modem is
    Realtek HD Audio
    Matte screen
    Notebook
    Fan cooled
    256Kbps
Could you post a screenshot of what you do have in you control panel
    Realtek HD Audio
    Matte screen
    Notebook
    Fan cooled
    256Kbps
I think Brink moved your thread
    Realtek HD Audio
    Matte screen
    Notebook
    Fan cooled
    256Kbps
Hi ,
I found this driver which should work.Just click the download link and save to your flash drive then install from your xp computer.
I hope this works. If it does succesfully install then just go to device manager and update the software for the rest of the hardware.
Netgear WG 311V3 Driver Download .
Keep us Posted.
Fastboy42
    Realtek HD Audio
    Matte screen
    Notebook
    Fan cooled
    256Kbps
