Ultimate 32 bit or 64 bit purchase question
Win95
I am wondering what version of Vista Ultimate I should purchase.
I assume that the Ultimate is better than the Premium that I have installed on another PC?
I want to install it on a home PC with a full installation.
I was also wondering if there is any advantage or limitations if I purchased a full OEM vs a full retail version?
I used to have XP OEM version on a PC and it had a limit of five reloads before you had to contact Microsoft to ask for another activation beyond that.
Thank you for any inputs about this.
    Q9450
    Dell TP406
    Crucial 4gb PC2-6400 800mhz
If you are running 4GB RAM or more then you want to get X64, if not go with X86. But that is really up to you. If you plan on upgrading to 4GB RAM, then go with X64.
I do not think there is any difference between the retail and OEM versions. The only real difference I know of is that the OEM must come with some sort of hardware and the retail version just comes with a CD and manual.
    Home Brew
    Intel E7200
    Gigabyte EP45-UD3P
    Kingston 4GB DDR2-800
    ATi Radeon HD3870 PCIe
    Creative Labs Audigy 2
    Samsung SyncMaster 940BW
    Seagate 7200.10 SATAII 250GB x2 RAID 0
    Western Digital 640AAKS
    Antec Neo550
    Antec P180
    Zalman 9500
    Logitech S510 Combo
    Logitech S510 Combo
    Comcast @ 10Mb
Hello Win95, Ultimate is basically the same system as home premium with a few addons that you may or may not need such as Bit-locker and Ultimate Extras. Most, if not all of the Extras are not necessary, I don't know of too many people who use Bit-Locker.
A comparison of the various Vista Versions is here :- Windows Vista: Versions compared - Operating Systems Software
    Scratch Built
    Intel Quad Core 6600
    Asus P5B
    4096 MB Xtreme-Dark 800mhz
    Samsung 206BW
    1680 X 1024
    550 w
    Thermaltake
    Microsoft
    Targus
    1500kbs
    Self built.
32 vs. 64: 64 bit is faster and has better security as well as more memory
home vs. ultimate: if virtualPC is useful get ultimate
oem vs retail: you will probably not have too many upgrades before windows 7 comes out so I would save the money and go with oem
    E8400
    asus p5ql-e
    ocz pc 1066 2x2gb
    asus eah3650 silent
    Edirol UA-25
    Gateway FPD2185W
    1680 x 1050
    750g samsung
    Zalman ZM460B 460W
    Lian Li A05 + 2 x Sythe S-FLEX SFF21D 120mm case fan
    Coolermaster Hyper Z600 fanless CPU cooler
    Merc Stealth
    Microsoft Laser Mouse 6000
    DSL
+1
As Norm pointed out, the Ultimate extras aren't really necessary (I don't use them, except for the extra sounds, which is no big deal at all;) ) and as Geezer mentioned, OEM is cheaper. Split the difference and go for an OEM Ultimate ;)
    i7 3770K HT ON 4.7GHz
    P8Z68 Deluxe Gen 3
    8GB G.Skill Ripjaws X 2133mhz
    X-FI Forte + ATH-AD900
    1920*1200 / 1920x1080
    Corsair AX1200W
    Lian Li PC-V1020A
    Laptop Specs:
    Clevo Sager P170HM //
    17.3 Matte 1920x1200 //
    i7 2720QM // 8GB 1333mhz //
    Dedicated GTX 485M //
    Samsung Story 2TB USB 3.0
Hi Win95, and welcome to the Vista Forums :party:
AFAIK the retail version of ultimate comes with Both 32 and 64 Bit DVD's and even if they don't MS will supply a 64 bit upgrade to 32bit retail for the cost of shipping only (about $10)
The OEM version is designed to be locked to a particular set of hardware and as such is not transferable between PC's, once installed, whereas the retail licence is transferable ( only one working install 32 or 64 bit at a time, of course ) ie may be un-installed and re-installed on another PC
Ultimate is a combination of the features of Vista Home Premium and Vista Business, plus a few Ultimate Extras, so if you are using at home with no need to connect to a business network (domain), remote access, etc then the Home premium is probably sufficient
just for your info :D
    2 x 1920x1080 @50Hz
    Asus M5A78L-M USB3
    32GB [4x8GB] DDR3 1600 MHz
    Asus nVidia GTX750TI-OC-2GD5 (2GB DDR5)
    Samsung 32" TV
    Internal
    Crucial CT256MX100SSD1 256GB SSD,
    Seagate ST2000DM001-1CH1 2TB,
    External (USB3)
    Seagate Backup+ Hub BK SCSI Disk 8TB
    2.5/3.5 Hot Swap Cradle, USB3 + eSata (client HDDs)
    NAS 4TB
    68 MB Down 18.5 MB Up
Thanks very much for the comments and suggestions.
I did order an Ultimate edition with SP1, for less than 170, with both the 32bit and 64bit DVDs. I won't be doing anything right away, the shipment is in process, but I do want to take my time and plan this out as best as I can before I make the change.
I had heard that if one uses a 64bit installation that it would better utilize the memory than the Premium 32 bit installation would. I am not sure if that is correct or not, but I do have 4gb 800mhz memory in this PC, and I want to use every bit of those resources.
I also heard that the 64bit edition would be harder to get all the hardware working properly because of the 64bit 'driver's' not being fully available? Again, I am not sure of this assumption either.
This will be a neat project for me to pursue as I do have some limited PC knowledge with some builds and XP installs to base this venture upon.
I have my own opinions about Vista, some good some not so good, and I see that Microsoft has one, as well vis-a-vis Windows 7 coming in 2010 or sooner.
Again, thanks for the information. This is a neat and courteous forum.
    Q9450
    Dell TP406
I have a 16 year old HP LaserJet4M that I plugged in via a USB to Serial cable, and x64 Vista recognized the printer without installing a single thing.
YMMV, but I'd say the driver issue is becoming close to non existent, though you will probably find hardware that simply won't get a 64 bit driver. Generally it's hardware that is long in the tooth anyway.
    Q9450 @3.4Ghz
    Asus P5Q Deluxe
    8GB Corsair Dominator @ 1066
    Asus AH4850
    Samsung 2235BW
    2x Seagate 750GB
    1x Seagate 160GB (IDE)
    Cooler Master Real Power Pro 850
    Cooler Master Cosmos
    Cooler Master V8
    Logitech WAVE Cordless
Hi Win95
Just one thing when you do get to the install if you install x64 take some of your ram out if possible. many users have had problems installing with more than 2Gbyte installed.
once the install is over re-install the other ram and it will work without problems, just tends to mess with the install :confused:
    2 x 1920x1080 @50Hz
    Asus M5A78L-M USB3
    Samsung 32" TV
    Internal
    External (USB3)
    NAS 4TB
Hello barman58, that is really good advice. It surprises me how many installations encounter problems just by not doing that.
    Scratch Built
    Asus P5B
    Samsung 206BW
    1680 X 1024
    550 w
    Thermaltake
    Microsoft
    Targus
    1500kbs
    Self built.
[FONT=&quot]64-bit is mega-fast with 64-bit apps as well as lets you upgrade > 4GB TOTAL RAM (system RAM + graphics card + other devices). 64-bit is more secure from viruses. 64-bit also requires “MS approved” (a.k.a. digitally signed) drivers so this “might” help with hardware compatibility, etc. This is MS’s way of trying to get everyone to “move on” if they are able to.
Differences and Advantages Between 32-bit (x86) VS 64-bit (x64) Windows Vista » My Digital Life
But if you have really old programs, they might not work (esp. with 64-bit version). Google “Vista compatibility list”. Knowing a bit about computers helps getting the old problematic ones to work (Internet has a lot of solutions that smart people share).
Ultimate is the best but if you don’t think you need anything that fancy, Home Premium is good too. Get a good video card if you want Aero graphics (at least 256MB 128-bit in the newer cards)… better if you can afford. Vista technology distributes more graphics processing to the video card and relieves the CPU for other things. This is KEY to Vista performance…a good video card will make Vista work well.
Vista uses extra RAM to store commonly used files in a new activity known as “disk caching” (SuperFetch). The computer uses artificial intelligence to determine which files will be used most and copies it to RAM (where it is much faster than accessing your hard disk). This includes components of the programs you use on a regular basis. When you need more RAM for programs you launch, etc. the computer purges the “least likely used” files from RAM to make room for the new program. So in theory, the more RAM (for disk cache) you have, the faster your computer will operate. This can also be augmented (to a lesser effect) with a flash drive/card with a technology called ReadyBoost. Just stick it in and select “Speed up my system” and leave it there. Google “AnandTech ReadyBoost Performance” for basic test examples.
Understanding how SuperFetch uses RAM to enhance system performance…
Understand how SuperFetch uses RAM to enhance system performance | Microsoft Windows | TechRepublic.com
High RAM will be especially helpful for those people who like to leave all their windows open and use Vista’s “S3 sleep mode” (2 watts) so they can resume where they left off almost immediately after they turn their computers on. Your apps are pre-opened where you left them and your RAM cache is loaded too, just as if you just walked away and came back.
Vista Home Premium and Ultimate has Windows Media Center, where with a TV card/USB adapter (if not integrated) of the type that fits your TV/Cable, acts similar to TiVo. You can play your videos, schedule recordings, etc. You can get a wireless keyboard / mouse or gyro-mouse and it will be sort of like remote control. If you do this, get a big Hard Disk.
[/FONT] [FONT=&quot]If this is any indication that 64-bit is the wave of the future and 32-bit will be “obsolete”…
There appears to be a shift taking place in the PC industry: the move from 32-bit to 64-bit PCs. [/FONT]
[FONT=&quot]We've been tracking the change by looking at the percentage of 64-bit PCs connecting to Windows Update, and have seen a dramatic increase in recent months. The installed base of 64-bit Windows Vista PCs, as a percentage of all Windows Vista systems, has more than tripled in the U.S. in the last three months, while worldwide adoption has more than doubled during the same period. Another view shows that 20% of new Windows Vista PCs in the U.S. connecting to Windows Update in June were 64-bit PCs, up from just 3% in March. Put more simply, usage of 64-bit Windows Vista is growing much more rapidly than 32-bit. Based on current trends, this growth will accelerate as the retail channel shifts to supplying a rapidly increasing assortment of 64-bit desktops and laptops… PC Accelerators built into Windows Vista, such as Windows SuperFetch, improve performance by keeping commonly used programs in memory, even when the program is closed. More memory capacity on 64-bit PCs allows SuperFetch to do its job more efficiently.
[/FONT]
[FONT=&quot][FONT=&quot]http://windowsvistablog.com/blogs/windowsvista/archive/2008/07/30/windows-vista-64-bit-today.aspx[/FONT][/FONT]
Some interesting 64-bit info:
...all 64-bit versions of Microsoft operating systems currently impose a 16 TB limit on address space and allow no more than 128 GB of physical memory due to the impracticality of having 16 TB of RAM. Processes created on Windows Vista x64 Edition are allotted 8 TB in virtual memory for user processes and 8 TB for kernel processes to create a virtual memory of 16 TB.
http://zone.ni.com/devzone/cda/tut/p/id/5709
[FONT=&quot]
[/FONT] Adobe Photoshop® Extended and Acrobat® Pro natively support 64-bit editions of Windows Vista. Adobe Premiere® Pro, After Effects®, Soundbooth®, Encore®, and Adobe OnLocation™ are certified on 64-bit Windows Vista.[FONT=&quot]
[/FONT]
Adobe - Adobe Creative Suite 4 Master Collection: System requirements
Adobe CS4 will be 64-bit, but only on Windows[FONT=&quot]
[/FONT]
BetaNews | Adobe CS4 will be 64-bit, but only on Windows
Adobe CS4 is 64-bit only on Vista. OSX have to wait for CS5 or something like that when they catch up.
To put things in perspective, this is what 64-bit does...
What are the advantages of 64-bit computing?
In early testing of 64-bit support in Photoshop for Windows®, overall performance gains ranged from 8% to 12%. Those who work with extremely large files may realize noticeably greater gains in performance, in some cases as dramatic as ten times the previous speed. This is because 64-bit applications can address larger amounts of memory and thus result in less file swapping — one of the biggest factors that can affect data processing speed.
Adobe Photoshop CS4: FAQ
