Power Supply check
panais
Power User
Is there any program that i can run and check my PS usage?
I have Sea sonic 700w 80plus and i will like to know if its capable to handle my hardware and how much is in use right now.
For now i have in my desktop:3 hard disks,1 dvd writer,4 dimms of ram,
1 ati radeon 3870x2,3 thermaltake smart case fan ll and 1 arctik cooling fan.
    Custom Built by me.
    Intel Core 2 Quad Q6600
    Gigabyte GA-X38-DS4
    KINGSTON HYPERX DDR2 4GB (2X2GB) PC6400 800MHZ DUAL CHANNEL KIT
    SAPPHIRE RADEON HD4890 OC 1GB GDDR5
    2/4/5.1/7.1-channel Realtek High Definition
    Samsung LE40A656F1 1080p 100Hz LCD HD TV 50,000:1
    1366x768 in Desktop,1920x1080p in gaming and video
    C:\WD VelociRaptor 150 GB,10,000 RPM
    D:\WESTERN DIGITAL WD15EADS 1.5TB CAVIAR GREEN SATA2 E:\WESTERN DIGITAL WD15EADS 1.5TB CAVIAR GREEN SATA2 No Raid.Copy Paste Is The Safest Way.
    Seasonic 700W 80plus
    A-Case Twin Engine BB
    3 thermaltake smart case fan II + 1 arctic cooling fan
    Wireless Logitech LX710
    Wirelles Logitech Laser Mouse MX620
    ADSL 4000plus
    F:\Sony high speed sata Dvd Rewriter
    KINGSTON HYPER X FAN
    +Cordless Rumblepad 2
Hi Panais,
No software that I know of, you can use a multimeter to check voltages on the various lines and thus work out current draw on the PSU and thus the power.
The easiest way is to add together the power "wattage" rating of each of your components (info should be available in documentation or on manufacturer's web site) a total of all the ratings at their highest load figure should give a worst case figure which should be less than your rated peak PSU output. The total of the "normal " Load figures of all the components that are working at the same time should be less than your continuous rating for the PSU.
This is of course an exercise based on quoted figures each component is different and also may vary over time.
Is this a general question or do you have reason to think the unit may not be upto the task?
    2 x 1920x1080 @50Hz
    Asus M5A78L-M USB3
    32GB [4x8GB] DDR3 1600 MHz
    Asus nVidia GTX750TI-OC-2GD5 (2GB DDR5)
    Samsung 32" TV
    Internal
    Crucial CT256MX100SSD1 256GB SSD,
    Seagate ST2000DM001-1CH1 2TB,
    External (USB3)
    Seagate Backup+ Hub BK SCSI Disk 8TB
    2.5/3.5 Hot Swap Cradle, USB3 + eSata (client HDDs)
    NAS 4TB
    68 MB Down 18.5 MB Up
<<Is this a general question or do you have reason to think the unit may not be upto the task?>>
From the day(before 2 days)i install 3 thermaltake smart case fan II my computer sims to act strange,sometimes stack on the startup screen,hard disk slow,internet getting slow.
    Custom Built by me.
    Gigabyte GA-X38-DS4
    ADSL 4000plus
