Solved Low Disk Space Problem
samo
Plz help I have Vista Home Premium running on a 320
GB hard drive. I keep getting the low disc space on C: error message, and
when I click on My Computer, it says I only have 189 MB of free space on the
C: drive. However, when I click on the C drive, highlight all the folders,
and click Properties, it says I am using 26 GB of space next to "size on
disk". I tried to solve this problem about a week ago by moving 30 gigs of
music to an external hard drive, but the C drive has filled up again even
though I have not added anything to the C drive. I've also tried using disk
cleanup and defrag, but that hasn't worked. This seems like a pretty serious
problem. What's the deal?
Thank you
Hello Samo, and welcome to Vista Forums.
Vista also has a lot of hidden system files, and it reserves hard drive space for items like the virtual memory paging file and system restore.
One main usual culprit is how much space is being used by System Restore. This tutorial will show you how to check to see how much it is using and how to adjust if you wanted to.
http://www.vistax64.com/tutorials/76227-system-restore-disk-space.html
    1TB Samsung 990 PRO M.2,
    4TB Samsung 990 PRO PRO M.2,
    Galaxy S23 Plus phone
You're welcome Samo.
