Another little problem... Start bar goes invisible..
Adamd
Vista Pro
Another little problem... Task bar goes invisible..
Ok so as I continue to use Vista I am running into a few minor problems along the way as I posted before, BUT:
My Task Bar just goes missing and all I can see is the Start button?
I reinstalled Vista the other day just because and it still does this and I have no idea why or how to fix it.
Drives me nuts. Only way to fix it short term is to restart and I hate doing that.
    Asus Laptop's = the best by far!
    Intel core 2 duo 2.5gig
    Asus
    4gigs DDR2
    Nvidia 9500m Gs 512mb
    15.4" laptop screen and 19" external
    1440x900 and 1280x1224
    250 in the laptop, 750gig external
I hope you mean taskbar, right?
OK, try this: Drag arrow to the bottom of screen until taskbar reappears, then right click taskbar, then click properties. Under Taskbar tab, uncheck the box on Auto-hide the taskbar. click apply, then ok.
Hope this helps.
PS....also lock it
    HP Pavilion dv7-1170us
    Intel Core 2 Duo T5800 @ 2.00GHz
    Compal
    NVIDIA GeForce 9600M GT
    1440 x 900
    289.09 GB
    IBM enhanced (101-or 102) keyboard
    Synaptics PS/2 Port TouchPad
    cable Wireless
Hi Adamd,
Sorry, but I don't think that CNY's suggestion will work. When Auto-hide the taskbar is checked, the start orb auto-hides along with the taskbar, with both reappearing together when required. I have been unable to replicate this problem of the start orb appearing on its own. I rather think you have got a corrupted file or files on your system. What I suggest is that you have a look at the following Tutorial (and its related links) to see if that helps: http://www.vistax64.com/tutorials/66978-system-files-sfc-command.html
    Dwarf Dwf/11/2012 r09/2013
    ASRock Z77 Extreme4-M
    ViewSonic VA1912w Widescreen
    Iomega 1.5TB Ext USB 2.0
    WD 2.0TB Ext USB 3.0
    Gigabyte IF233
In addition to Dwarf's suggestion, you might want to run a through malware scan just to rule that out. Have you tried stopping explorer.exe and reinitializing it. Have you downloaded anything before this started happening? (toolbars, etc.)
    Airbot 2.0
    EVGA Nvidia GTX 480 -Fermi
    ASUS Xonar D2X
    1920x1080@60hz
    1 OCZ Vertex2 180GB SSD
    Pioneer DVD Burner DVR-S18M
    Corsair HX1000W
    Cooler Master HAF 932
    Logitech Wireless MK700
    Windows 7
    W.E.I final score= 7.7
    Windows Vista=5.9
Well I just reinstalled Vista like 2 days ago and has happened before as well.
Auto hide is not on.
Really odd... I was thinking this was a common problem since it happened after 2 installs of Vista...
    Asus
    4gigs DDR2
Ok small update.
If I change it to "auto hide" and turn it back off the task bar comes back.
This may work for a day or 2, but this problem always seems to come back for no reason whenever it feels like it.
    Asus
    4gigs DDR2
It happended to me with XP. I solved it accidentally by booting in safe mode...and back to normal boot. (I might have done some blind tweakings while in safe mode...not sure).
And it happened to a friend, also with XP...and it was due to trojan malware (Vundo?)
Suggestions:
Boot in safe mode (what the heck...it won't harm) and back again in normal boot. See what happens.
Run anti-virus scan.
    Compal
    1440 x 900
    289.09 GB
    cable Wireless
Ok small update.
I had a similar problem where the taskbar dissapears.
In my situation I am using a Acer laptop and make use of an external monitor. When I remove the external monitor, the taskbar dissapears.
Acer laptops have a "Presentation" button. If I use the button to activate/deactivate the monitor, the taskbar "fixes itself".
I never get this problem....
    Acer Aspire 5593
    Core2Duo T5500 1.66 Ghz
    2048 Gb
    ATi mobility X1600
    My Nb is'nt hot
Ok small update.
1. Type regedit in run,
And expand h key local machine\software\Microsoft\windowsnt\currentverson\winlogon, in the right pane double click on shell, delete all the values and type explorer.exe there.
2. press ctrl+alt+esc, this key combination should bringback ur taskbar.
3. If u changed the dpi settings bring back into default settings.
Let me know the result :)
    Wipro
    Intel dq35j0
    8 Gb
    inter express chipset
    Realtek
    Wipro
    1024*768
    500 gb
    DELL
    Dell
    100 mbps(office lan)
Maybe.....
Video Drivers? Uninstall/Reinstall, maybe try a different version.
Honestly,, I have never ever seen this on any system I have ever worked on.
So,, I have to think it is OS corruption, Hardware causing corruption, This is not a typical Windows problem that I have ever seen or read about. And I have worked on a whole lot of systems.
I have this problem also. It tends to happen after I resume my Dell Latitude D820 laptop after it has been suspended (sleep). The only thing that restores the taskbar for me is to click on "Switch user" and just log back in as myself.
I'm running Vista Ultimate SP1 32 bit.
