strange problem
affan
Hi!
I am a new user of windows vista home premium, I have been suffering from a strang problem somtimes I open any file some of the thing remove from my destop and my mouse's right click didn't work
here is the picture of my problem
please help me otherwise i have to go back to xp:(
  • Motherboard
    intel dg31pr
    2gb
    integrated 256mb
Hello Affan, and welcome to Vista Forums.
If you have recently tried to change or remove the shortcut arrow overlay icon, then this will show you how to restore the default shortcut arrow to fix the shortcut icons.
http://www.vistax64.com/tutorials/67615-shortcut-arrow.html
If this is not the case, then you can try a System Restore using a restore point dated before this happened to hopefully fix it.
    1TB Samsung 990 PRO M.2,
    4TB Samsung 990 PRO PRO M.2,
    Galaxy S23 Plus phone
First of all thanks for replying me but guys you can't understand my problem i happen some times that i am listening songs or playing games that during this i open any other file my start menu doesn't work many icons rremove from the taskbar
  • Motherboard
    intel dg31pr
    2gb
    integrated 256mb
Affan, I would recommend doing the System Restore option posted above. If it has not happened to long a go, you may be able to fix it with that. :)
i used system restore option but it didn't work please help me out
i don't know what to do
  • Motherboard
    intel dg31pr
    2gb
    integrated 256mb
Have you tried using older restore point dates?
Do you remember if you installed or changed anything before this started?
Thank you brink for reply but this problem is not permanent it just happened any time i can't click anywhere, the programs from my taskbar goes right and left when i click on start menu it sows a emty box(only borderline) and when i restart my windows it backs to normal
  • Motherboard
    intel dg31pr
    2gb
    integrated 256mb
Possibly a video driver issue. You might uninstall and reinstall this driver to see if it may help. Double check to be sure that you have the latest driver version as well.
nohting happened now i have the latest video driver please solve my problem otherwise i have to install windows xp
  • Motherboard
    intel dg31pr
    2gb
    integrated 256mb
You might try a clean reinstall of Vista followed by all of your drivers and Windows Updates. Be sure to backup anything that you do not want to lose first though.
Sounds like an overheating issue, to me.
    Me/Bertha4
    (2) Amd Athlon 64 FX74 Dual Core @ 3.4gigs
    Asus L1N64-WS Sli (680a)
    8Gb (4X2Gb)OCZ PC2 6400 Gold Edition
    (2) EVGA GeForce 8800 Ultra 768Mb PCIe-Sli Mode
    LG Flatron Wide 24"
    1920x1200
    (2) WD 150Gb RaptorX
    (1) WD 320Gb
    1200W Toughpower
    Nvidia Branded CoolerMaster Stacker 830
    Refrigerated Air
    Microsoft Wireless Entertainment Keyboard 7000
    Microsoft Wireless Laser Mouse 8000
    DSL
    Logitech® Z-5500 Digital Sound System
