Ntdll Error 0xc000007b Pls Help
Jay Bee Kay
Pls HELP ME ASAP!! this error been workin on my @ss for sum time now
first of all no its not just with one program so that "fix" of try re installing the program its not that
i searched google cnt find anything
the ntdll is stopping a few programs (the most important ones) from running
i found this AVZ Antiviral Toolkit and it gave me this results :
Attention !!! Database was last updated 2/8/2009 it is necessary to update the bases using automatic updates (File/Database update)
>>>> Danger - the avz.exe file is changed, check of its CRC by Trusted Objects Database failed
AVZ Antiviral Toolkit log; AVZ version is 4.30
Scanning started at 7/9/2009 4:13:15 AM
Database loaded: signatures - 209302, NN profile(s) - 2, microprograms of healing - 56, signature database released 08.02.2009 18:56
Heuristic microprograms loaded: 372
SPV microprograms loaded: 9
Digital signatures of system files loaded: 91560
Heuristic analyzer mode: Medium heuristics level
Healing mode: disabled
Windows version: 6.0.6000, ; AVZ is launched with administrator rights
System Restore: enabled
1. Searching for Rootkits and programs intercepting API functions
1.1 Searching for user-mode API hooks
Analysis: kernel32.dll, export table found in section .text
Analysis: ntdll.dll, export table found in section .text
Function ntdll.dll:NtCreateFile (228) intercepted, method CodeHijack (method not defined)
Function ntdll.dll:NtCreateProcess (241) intercepted, method CodeHijack (method not defined)
Function ntdll.dll:NtCreateProcessEx (242) intercepted, method CodeHijack (method not defined)
Function ntdll.dll:NtCreateUserProcess (254) intercepted, method CodeHijack (method not defined)
Function ntdll.dll:NtDeviceIoControlFile (269) intercepted, method CodeHijack (method not defined)
Function ntdll.dll:NtOpenFile (340) intercepted, method CodeHijack (method not defined)
Function ntdll.dll:NtQueryInformationProcess (394) intercepted, method CodeHijack (method not defined)
Function ntdll.dll:ZwCreateFile (1431) intercepted, method CodeHijack (method not defined)
Function ntdll.dll:ZwCreateProcess (1444) intercepted, method CodeHijack (method not defined)
Function ntdll.dll:ZwCreateProcessEx (1445) intercepted, method CodeHijack (method not defined)
Function ntdll.dll:ZwCreateUserProcess (1457) intercepted, method CodeHijack (method not defined)
Function ntdll.dll:ZwDeviceIoControlFile (1471) intercepted, method CodeHijack (method not defined)
Function ntdll.dll:ZwOpenFile (1541) intercepted, method CodeHijack (method not defined)
Function ntdll.dll:ZwQueryInformationProcess (1595) intercepted, method CodeHijack (method not defined)
Analysis: user32.dll, export table found in section .text
Analysis: advapi32.dll, export table found in section .text
Analysis: ws2_32.dll, export table found in section .text
Analysis: wininet.dll, export table found in section .text
Analysis: rasapi32.dll, export table found in section .text
Analysis: urlmon.dll, export table found in section .text
Analysis: netapi32.dll, export table found in section .text
1.2 Searching for kernel-mode API hooks
Driver loaded successfully
SDT found (RVA=1278C0)
Kernel ntoskrnl.exe found in memory at address 82000000
SDT = 821278C0
KiST = 8205607C (398)
Functions checked: 398, intercepted: 0, restored: 0
1.3 Checking IDT and SYSENTER
Analysis for CPU 1
Analysis for CPU 2
Checking IDT and SYSENTER - complete
1.4 Searching for masking processes and drivers
Checking not performed: extended monitoring driver (AVZPM) is not installed
1.5 Checking of IRP handlers
\FileSystem\ntfs[IRP_MJ_CREATE] = 85A171F8 -> hook not defined
\FileSystem\ntfs[IRP_MJ_CLOSE] = 85A171F8 -> hook not defined
\FileSystem\ntfs[IRP_MJ_WRITE] = 85A171F8 -> hook not defined
\FileSystem\ntfs[IRP_MJ_QUERY_INFORMATION] = 85A171F8 -> hook not defined
\FileSystem\ntfs[IRP_MJ_SET_INFORMATION] = 85A171F8 -> hook not defined
\FileSystem\ntfs[IRP_MJ_QUERY_EA] = 85A171F8 -> hook not defined
\FileSystem\ntfs[IRP_MJ_SET_EA] = 85A171F8 -> hook not defined
\FileSystem\ntfs[IRP_MJ_QUERY_VOLUME_INFORMATION] = 85A171F8 -> hook not defined
\FileSystem\ntfs[IRP_MJ_SET_VOLUME_INFORMATION] = 85A171F8 -> hook not defined
\FileSystem\ntfs[IRP_MJ_DIRECTORY_CONTROL] = 85A171F8 -> hook not defined
\FileSystem\ntfs[IRP_MJ_FILE_SYSTEM_CONTROL] = 85A171F8 -> hook not defined
\FileSystem\ntfs[IRP_MJ_DEVICE_CONTROL] = 85A171F8 -> hook not defined
\FileSystem\ntfs[IRP_MJ_LOCK_CONTROL] = 85A171F8 -> hook not defined
\FileSystem\ntfs[IRP_MJ_QUERY_SECURITY] = 85A171F8 -> hook not defined
\FileSystem\ntfs[IRP_MJ_SET_SECURITY] = 85A171F8 -> hook not defined
\FileSystem\ntfs[IRP_MJ_PNP] = 85A171F8 -> hook not defined
Checking - complete
2. Scanning memory
Number of processes found: 53
Number of modules loaded: 505
Scanning memory - complete
3. Scanning disks
F:\Program Files\Common Files\microsoft shared\ink\pipanel.exe >>> suspicion for Backdoor.Win32.Agent.px ( 07CD3C40 000ED0BE 0001F605 0028BBC5 28160)
Direct reading F:\Windows\System32\drivers\sptd.sys
F:\Windows\System32\wiawow32.sys >>> suspicion for Trojan-Clicker.Win32.Pamere.cc ( 0037591C 01BF58DB 00110A55 00086F7F 36864)
F:\Windows\winsxs\x86_microsoft-windows-t..acyinkingcomponents_31bf3856ad364e35_6.0.6000.16386_none_3fbb09cf8caa385d\pipanel.exe >>> suspicion for Backdoor.Win32.Agent.px ( 07CD3C40 000ED0BE 0001F605 0028BBC5 28160)
4. Checking Winsock Layered Service Provider (SPI/LSP)
LSP settings checked. No errors detected
5. Searching for keyboard/mouse/windows events hooks (Keyloggers, Trojan DLLs)
6. Searching for opened TCP/UDP ports used by malicious programs
Checking disabled by user
7. Heuristic system check
Checking - complete
8. Searching for vulnerabilities
>> Services: potentially dangerous service allowed: TermService (@%SystemRoot%\System32\termsrv.dll,-268)
>> Services: potentially dangerous service allowed: SSDPSRV (@%systemroot%\system32\ssdpsrv.dll,-100)
>> Services: potentially dangerous service allowed: Schedule (@%SystemRoot%\system32\schedsvc.dll,-100)
> Services: please bear in mind that the set of services depends on the use of the PC (home PC, office PC connected to corporate network, etc)!
>> Security: disk drives' autorun is enabled
>> Security: administrative shares (C$, D$ ...) are enabled
>> Security: anonymous user access is enabled
>> Security: terminal connections to the PC are allowed
>> Security: sending Remote Assistant queries is enabled
Checking - complete
9. Troubleshooting wizard
>> Abnormal COM files association
>> Service termination timeout is out of admissible values
>> HDD autorun are allowed
>> Autorun from network drives are allowed
>> Removable media autorun are allowed
>> Invalid autorun item
Checking - complete
Files scanned: 43897, extracted from archives: 21808, malicious software found 0, suspicions - 3
Scanning finished at 7/9/2009 4:18:06 AM
Time of scanning: 00:04:52
If you have a suspicion on presence of viruses or questions on the suspected objects,
you can address VirusInfo conference
I dnt knw what caused this problem but pls any help would be greatly appreciated
try typing sfc /scannow in an elevated command prompt (run with admin privelages) this will scan your dll library and replace any damamged / faulty one , you will need your operating system dvd
    XFX 780i
    4GB OCZ PC2-8500C5 DDR2
    Gainward GTX260/216 SLI
    Creative X-FI Xtreme Gamer
    Dell UltraSharp 2209WA 22"
    OCZ Modstream 700w
    Titan Fenir
    Razer Reclusa
    Logitech G5 Gamer
    8mb
