Help Irritating Pop Ups
msparrot
:confused: I have Windows Vista on my laptop and I use avast antivirus downloaded free from the internet.
I also have my popup blocker on but keep getting these irritating popups almost every 2 minutes when using my internet explorer. I have to keep deleting them. I have tried to delete all my history and cookies but this does not work either. I notice that when I use another user profile on my computer it does not happen.
Please help this is driving my mad.
msparrot
I think you are going to have to tell us more about the pop ups. are they warnings, what app is generating them? tell us asmuch as you can
Ken
    Dell Inspiron E 1405
    [email protected]
    4 gigs
    integrated intel 945
    integrated
    300 gig internal
    10 down 1.5 up
Sorry I didn't give more information. The popups that come up are new windows that open up from different websites like dating websites, eshopping websites, gambling but to name but a few. Also websites advertising slimming pills. Acia berry (I think is one of them)
Hope you can help.
You said you have your Pop-Up Blocker on, but didn't mention the specific settings within the Pop-Up Blocker. Try this: go into Internet Explorer, Tools, Pop-Up Blocker, and Pop-Up Blocker Settings.
In Pop-Up Blocker Settings, at the bottom of the screen, open Blocking Levels, and select either Medium or High.
At the very bottom of the same screen is a link entitled: "Learn more about Pop-Up Blocker" that has a lot of additional information from Microsoft. You can read it all at your leisure, but here's some relevant info from that page that might help:
"I turned on Pop-up Blocker but I still see some pop-ups. Why?"
The following are some common reasons why you might still be seeing pop-ups:
  • You might have software, such as adware or spyware, on your computer that is opening pop-up windows. To stop these pop-ups, you will have to identify the software that is opening them and then remove it or change its settings to stop it from opening pop-up windows. For information about detecting and removing adware and spyware, see Spyware: frequently asked questions.
    Some windows with active content are not blocked.
  • Internet Explorer will not block pop-ups from websites that are in the Local intranet zone. If you want the pop-ups from these websites to be blocked, you have to remove the websites from this zone. For more information, see Security zones: adding or removing websites.
P.S. You might also try raising your Security and Privacy levels in the Internet Explorer, Tools Security and Privacy sections.
    HP Pavillion dv5t (Gen. 1)
    1680 x 1050
    built in - HP
    max
