Water Cooling Question
lil domii
Seven Guru + GFX
Power User
hi everyone,
i know that water cooling is less noisy, takes up less room and cools more efficiently. but how much do the temperatures drop on average from standard air coolers? i want to have a go at decent overclocking when i build my new rig ;)
(not what it drops down to, how much it cools down :p)
thanks,
Dom
    Acer 5735z Laptop
    2.0 ghz intel pentium dual-core processor t4200 800mhz fsb
    Acer CathedralPeak Rev
    4gb
    Integrated Intel Graphics Media Accelerator 4500
    Realtek
    15.6" HD CineCrystal LCD
    1366x768
    160gb stock drive. ATA
    Stock Notebook
    Stock
    PS/2
    Synaptics TouchPad
    No idea
Hello lil domii,
I overclock all my rigs, (check my specs), but i have yet to be convinced that water cooling is worth the expense, my temps never go above 50C under load and that is on air cooling.
If you can keep your temps down to an acceptable level, then it doesn't matter how you do it.
I like the fact that if my cooling goes wrong, it can be fixed with another fan or heatsink, in minutes.
Dont get caught up in the hype.
Any way, thats my 2 bobs worth, good luck.
    Self Build
    Asus P5Q Premium
    2 x ASUS EAH 4870 X 2 (Quad)
    Supreme FX 2
    150 Gig WD Raptor
    300 Gig Maxtor
    300 Gig Maxtor, (External)
    CoolerMaster 1000
    Logitech G15
    Logitech G5
    20Mbps
hi everyone,
thanks,
Dom
Stick with air for your first time around to get the hang of Overclocking. It's cheaper, easier and you can still get a good overclock.
Watercooling is only necessary when going for very high (4ghz+) overclocks with voltages that exceed the 'max safe' values.
    i7 3770K HT ON 4.7GHz
    P8Z68 Deluxe Gen 3
    8GB G.Skill Ripjaws X 2133mhz
    X-FI Forte + ATH-AD900
    1920*1200 / 1920x1080
    Corsair AX1200W
    Lian Li PC-V1020A
    Laptop Specs:
    Clevo Sager P170HM //
    17.3 Matte 1920x1200 //
    i7 2720QM // 8GB 1333mhz //
    Dedicated GTX 485M //
    Samsung Story 2TB USB 3.0
as others have said, its not a big drop really, 5-6c some claim up to a 10c drop.......
i also would never go WC, my air config is 2nd to none :) (if you dont mind a little noise, but while gaming with the headset it makes no odds)
i have a CM590 case with a full front grill, ive removed all standard CM 120mm fans & replaced all of them with server fans (2x 120x38mm delta's @ 135CFM each...... 3x 92x38mm AVC @ 100CFM & vantec @ 113CFM
all wired into a ''lamptron military bay bus controller''.....
while idle i run only one fan, the CPU fan @ 20%, & the rig is silent @ the flick of a switch im pulling 300CFM through the front of my case...:eek::eek: @ about 50db
this setup cost peanuts compared to a decent WC setup & mine probably performs better...
now this is a far less hassle & ''better performing'' setup than water, its just obviously louder... but a WC setup is not silent unless you keep your rad in another room, the 3x 120mm fans are still audible...
check out my idle & load temps...;)
idle....
load...
    ME.....
    Q9450 @ 3.6ghz
    P5K PREMIUM
    8GB 1066mhz buffalo firestix
    HD 5970
    20'' syncmaster
    XCILIO 850w
    unknown ATX
    Arctic cooler pro 775
    logitech EX110
    logitech cordless optical
    2mb
I've seen different outcomes with watercooling. If you don't set it up properly, then you get bugger all in terms of temp drop. If setup properly, then you can get quite a considerable drop in temp.
The PC a mate of mine has has watercooling in it, just one to cool the CPU. He had his radiator next to his PC under his desk, so was still sitting at 30C idle and in the 40s for load temps, which is pretty much what I get on my CPU on air cooling. He then moved his PC on to his desk and put his radiator on to his window ledge and that's when the temps really dropped.
At idle his i7 920 sits at 19-20C, it's been overclocked to 3.4GHz. At load, it gets to about 35C when running prime95, which leaves a lot of headroom for more overclocking when he upgrades his RAM from 1333MHz.
I'll try and get some screenshots when I see him.
Edit: He's posting the screenshot himself.
Edit: Just watched him take that screenshot and when prime95 has stoppedbenching , the temps drop back down to idle in pretty much a few seconds.
    Intel Core 2 Quad Q9550
    XFX MB-750I-72P9 NF750i
    4096MB Corsair XMS2 PC-5400
    ASUS Nvidia Geforce GTX470
    ASUS Xonar DX
    1920x1080 & 1680x1050
    Logitech G11 Keyboard
    100Mbps
Im the guy "Everlong18" was talking about, at Idle my CPU sits at 15-22c and at Load the highest any core gets to is 37C.
    Intel Core i7 920 @ 3.4Ghz
    Asus P6T6 WS Revolution x58
    6144mb Corsair XMS3 DDR3
    3x XFX 8800 Ultra XXX
    Asus Xonar HDAV1.3 Deluxe
    Iiyama prolite 24" / Dell Ultrasharp 20" widescreen
    1920 x 1080 / 1680 x 1050
    2 x seagate 500Gb NCQ
    Coolermaster Real Power Pro 1250w
    Thermaltake Armor+
    Water Cooling
    Razer Lycosa Mirror
    Razer Lachesis
    100 mb/s
    Razer destructor mousemat
    Steel series siberia headset
    Logitech z-5500
ok, thanks everyone, sorry for the mid-late reply, i have taken in wht you said, and will just get a £10 air heatsink. :)
Dom
    Acer 5735z Laptop
    4gb
    Realtek
    1366x768
    Stock Notebook
    Stock
    PS/2
    Synaptics TouchPad
    No idea
    Acer 5735z Laptop
    4gb
    Realtek
    1366x768
    Stock Notebook
    Stock
    PS/2
    Synaptics TouchPad
    No idea
On watercooling
    Thermaltake Armor+
    Water Cooling
    Razer Lycosa Mirror
    Razer Lachesis
    100 mb/s
    Logitech z-5500
hello harry........ ;)
yes there's certainly more than a few crap WC loops about.
Welcome kungpow1975......:)
those are some nice temps mate, what kind of cooling setup is built on the rad..??, how far away is the rad from the tower..??
    ME.....
    Q9450 @ 3.6ghz
    P5K PREMIUM
    HD 5970
    20'' syncmaster
    XCILIO 850w
    unknown ATX
    logitech EX110
    2mb
Its the "Black ICE GT eXtreme 480" 480mm Radiator, with a "Laing DDC-1T Ultra 18w" Pump, and The "Laing DDC Top Reservoir", with a EK-Supreme Plexi S1366 Block. The Radiator Has 4x Xigmatek 120mm orange/White Fans (See Pics Below!!!).
As you can see the radiator is right next to the tower.
    Thermaltake Armor+
    Water Cooling
    Razer Lycosa Mirror
    Razer Lachesis
    100 mb/s
    Logitech z-5500
He was too lazy to take a new photo. He currently has his radiator sat on his window ledge with the fans blowing cold air from the window through his radiator ;)
    ASUS Xonar DX
    100Mbps
Heres the new pictures as Harry pointed out that i was too lazy.
Radiator
CPU Block
PUMP and Reservoir
    Thermaltake Armor+
    Water Cooling
    Razer Lycosa Mirror
    Razer Lachesis
    100 mb/s
    Logitech z-5500
Damn,how much is water cooling?
    Intel(R) Core(TM)2 Quad CPU Q8400 @ 2.66GHz
    Elitegroup P43T-AD3
    4.0GB Ram DDR3
    GeForce 9600 GT
    Lenovo 1440 X 900 60Hz
    1440 X 900
    1TB
    Acer 5735z Laptop
    4gb
    Realtek
    1366x768
    Stock Notebook
    Stock
    PS/2
    Synaptics TouchPad
    No idea
    P8Z68 Deluxe Gen 3
    Corsair AX1200W
    Lian Li PC-V1020A
    Laptop Specs:
Thanks Smarteyeball, i have to give everlong18 some credit as he helped me build it.
    Thermaltake Armor+
    Water Cooling
    Razer Lycosa Mirror
    Razer Lachesis
    100 mb/s
    Logitech z-5500
    Acer 5735z Laptop
    4gb
    Realtek
    1366x768
    Stock Notebook
    Stock
    PS/2
    Synaptics TouchPad
    No idea
Hi, as a Watercooling user it may seem a bit weird for me to be saying this, but a Air cooler for around £60 will be much better than any watercooler for the same price, so i would reccommend the air cooler. What smarteyeball said about watercooling is correct, the more you invest in it... the better it is. i would say go for air cooling if your budget is around £60
    Thermaltake Armor+
    Water Cooling
    Razer Lycosa Mirror
    Razer Lachesis
    100 mb/s
    Logitech z-5500
My old Aircooler before i switched to watercooling was excellent.
it was the "Asus Triton 81". Its £37-£45 at the moment and is dual fanned. The only problem is it has fixing clips instead of screws. but once you figure out how to secure them, it goes on fine and it keeps the CPU relatively cool
    Thermaltake Armor+
    Water Cooling
    Razer Lycosa Mirror
    Razer Lachesis
    100 mb/s
    Logitech z-5500
