I have the CAPS LOCK/NUM LOCK enabled so that I can tell when I accidentally turn them on.
I use Vista Home Premium; Asus Laptop.
I use Logitech's Cordless Number Pad for entering numbers and the laptop's number pad with the NUM LOCK key set to OFF to navigate around the screen.
With the Num Lock OFF I get keypress sounds whenever I use the L/T Num Pad. I don't have the problem with the Num Lock OFF.
Is there a way of disabling the keypress sounds from the L/T Number Pad while keeping them on for the laptop (without having to press the NUM LOCK key - otherwise I wouldn't have bought the Pad)?
I have emailed Logitech about this and waiting for their reply but I think this is more of a operating system issue.
