Help choosing a CPU Cooler for overclocking
nostaw5
"POW" Ur dead
Power User
I now have a home built AMD pc which came with a Foxconn AMD Certified CPU Cooler (AKA Stock cooler).
I overclock my Athlon II X2 255 from 3.1 to 3.8...
Now here is the problem. The temps sit at 45c with the Stock cooler but 36c with an Aywun A10 (or something) BUT HERE ARE THE PROBLEMS:
Stock cooler good side: quiet, small, mobo controlled fan.
Stock cooler Bad side: Hot, small, not much to look at.
AYWUN A-10 good side: Big to look at, keeps cpu cool
AYWUN A-10 bad side: Under load gets loud, big (maybe restricts airflow) have to use fan controller to keep quiet.
So my fellow overclockers which do you reccomend i use?
    Custom Gaming Rig 780G
    AMG Athlon II X2 255 3.8/2MB/2500MHz 45nm AM3
    Gigabyte GA-MA78LMT-S2 AM3, Core Boost, Ultra Durable 3
    2X 4GB Kingston DDR3 1066MHz @ 1666MHz Dual Channel
    HIS HD Radeon 7770 GHz Edition iCooler Core: 1000MHz
    Realtek HD Audio
    Dell E2311H DVI/VGA 5ms response, Full HD
    1920x1080 @ 60Hz
    320GB Seagate Barracuda 7200.02 SATA II
    Cooler Master Extreme Power Plus 700w
    Lian-Li PC-6010 With Side Window
    Aywun A4 80mm fan
    Logitech K120 Wired Keyboard
    Logitech K120 Wired Mouse
    802.11B/G/N 17Mb/s
    AMD Catalyst 12.6
    Thomson A/B/G/N Router
    LiteON CD/DVD Player
    GAME PERFORMANCE:
    Battlefield 3: 41 FPS High 1x AA @ 1280x720
    Mass Effect 2 and 3: 60 FPS Highest 4x AA @ 1920x1080
    Counter Strike Source (and other Valve games):
    300 FPS (max FPS in game) Highest settings 8x AA 16x AF @ 1920x1080!!!
45C isn't bad. I don't know about yours but my computer shuts down at 75C. Intense gaming might increase it by 10-15 degrees but you'd still be "safe" or as safe as you can be for that much overclocking. Typically the more efficient coolers are larger and can be noiser although 120 mm fans don't typically have to run as fast. Off course those are on larger heat sinks. I'm not sure how to answer your question other than to say it's personal preference.
    Windows 8.1 Industry Pro x64
    HP Pavillion Elite HPE-250f
    8 gb
    ATI Radeon HD 5770 1 gb ram
    Alienware 25 AW2521HF
    1920x1080 &1680x1050
    1 TB x2
    Dell Poweredge T140
    8GB 2666MT/s DDR4 ECC UDIMM
    1 TB & 360 GB x2
OK thanks, i found out its actually a A1-V4 with an 80mm fan and the heatsink size is roughly the size of the fan too. Both the fans are controlled by fan controllers. Just a question but but the aywun heatsink sits on the cpu with the fan pointing towards the drive bays... meanwhile the stock sits like normal... does this restrict airflow?
    Realtek HD Audio
    1920x1080 @ 60Hz
    Aywun A4 80mm fan
    802.11B/G/N 17Mb/s
    AMD Catalyst 12.6
    GAME PERFORMANCE:
I don't really know a lot about heat sink design.
    8 gb
    1 TB x2
    Dell Poweredge T140
    1 TB & 360 GB x2
Well, I just bought a Be Quiet Dark Rock Pro: Be Quiet Dark Rock PRO BK016 CPU Cooler - Scan.co.uk
and it is excellent! But I cannot stress just how huge it is...
I have a big case, and it just fitted in (I couldn't slide in the motherboard tray from the rear, how to remove the motherboard tray bottom rail, slide up the tray, reinstall the bottom rail whilst holding up the tray in some precarious maneuver, and then the case side fitted on with literally half a centimetre to spare.
But despite it being huge, and being the most evil looking cooler I have ever seen :p, I love it (but it sounds like an aeroplane at full power - which fortunately it rarely reaches)
Richard
    Dell XPS 420
    Stock Dell 0TP406
    4 gb (DDR2 800) 400MHz
    1600 x 1200 and 1280 x 1204
    1 x 640Gb (SATA 300)
    1 x 1Tb (SATA 600)
    Stock PSU - 375W
    Dell XPS 420
    Stock Fan
    Dell Bluetooth
    120 kb/s
Nieriro.. that looks like a noctua nh-d14... very nice.
Nostaw. Firstly, you can point the fan any way you want. I'd remove and turn the fan around by either switching the actual fan, or by switching the entire heatsink around. Pumping hoit air into your case is bad.
2nd I'd switch out the fans for quality fans... Find quieter fans, though you have 80mm which trend to run faster to get the same air flow.
I think turning your fans to exhuast out the back should be your 1st thing, as it'll cool better so you can run slower and quieter.
Is you 45C load or idle?
    Dual L5639 // i7 950 @ 4.0Ghz
    gtx 560 ti // gtx 260-216
    Dual 22" // Headless
