Dual Monitor graphics card
sabbaefie
I have a new computer with Vista Home Premium x64. I used a dual monitor graphics card in my old computer with Windows XP. Took the card out and install it in my new computer and updated the driver. But, performance is poor. For example I can't use Vista Aero.
I would like to buy a new, relatively inexpensive dual monitor graphics card which is compatible with Vista premium x64. Any suggestions?
What card do you have, maybe it's not old.
    Intel Core 2 Duo E8400
    ASUS P5B-E Plus
    4GB Kingston ValueRAM DDR2-667
    ASUS EN8800GT 512
    Creative X-Fi XtremeGamer
    Packard Bell Maestro 190W
    1440x900 @ 75Hz
    WesternDigital 200GB 7200RPM + Iomega Desktop HD 360GB 7200RPM
    Xilence Power 600W Gaming Edition
    Coolermaster Centurion 534 Black
    Standard Coolermaster Case Fans + Standard Intel CPU Fan.
    Logitech G15 V1
    Razer Copperhead Tempest Blue
    100.0 Mbps
i think it would help to know a little about your old card and new p.c before be can give true advice and suggestions
i mean i could say 9800GX2 but this may not be in your budget, to big for your case or even be the wrong card for your chipset
    Me :P
    Core 2 Quad Q6600
    Abit IN9 32X MAX
    Realtek 7.1 CH HD Audio
    1280x1024 + 1360x768
    150GB Raptor HDD
    500GB Caviar HDD
    Thermaltake W0133RB 1200W PSU
    Antec 900
    Stock + Antec 900 case fans
    Logitech G15 (full layout)
    Logitech MX Revolution
now presuming that the card you took out of you new system was Nvidia and that your running on a small budget i can now suggest an XFX Geforce 8600GT 512MB DDR2 PCI-E
£58.07 inc. VAT
or if you have a larger budget then you could have an
XFX GeForce 8800GT Alpha Dog XXX 512MB PCI-E 2.0
£144.47 inc. VAT
however be sure to read the tech spec's b4 you do go get one
if the card you took out of the new pc was an ATI i suggest that you look at getting an ATI card replacement
be sure it will fit in you case, make sure you power supply meets the requirements
and make sure you have enough spare dims to connect any required supplementary power
    Me :P
    Core 2 Quad Q6600
    Abit IN9 32X MAX
    150GB Raptor HDD
    500GB Caviar HDD
    Antec 900
GeForce FX 5200/256 MB DDR/PCI/Dual VGA
That is definitely an nVidia card.
Your budget is pretty much your limiting factor...However, that card you have is a *PCI* card as you have listed - does your new computer already have onboard video? If not, you'll be looking for a new PCI-e GA - Depending upon your budget again.
I purchased the eVGA 8800 GTS 512MB JO edition and am mostly satisfied with it, for the money.
    The Beast Model V (homebrew)
    Realtek HD Audio (onboard)
    2 * 1920 x 1080
    Logitech G15 (gen 2)
    Logitech MX Master (shared)
    Lenovo ThinkPad E545
    AMD A6-5350M APU
    Lenovo
    Radeon HD (Embedded)
    Conextant 20671 SmartAudio HD
    Lenovo 15" Matte
    1680 * 1050
    Lenovo
    Lenovo
    Lenovo
    Lenovo
