crodrigues
Hi guys,
I was using vpn connection with vista 32 with no problem. Now, i am trying to do the same in vista 64 bit and the connection fails.
I followed instructions to disable tcp/ip v6, and configure tcp/ip v4 properties setting a DNS address. Even with these modifications it still doesnt work.
Does anyone have an idea what should i try next?
thanks
thanks
