no sound play dvr-ms or Live TV
Fgrefe
I have HP, vista, media center, HDMI cable for sound and video. When I play recorded TV or live TV I get no sound. However I get sound if I play AVI file, and running audio test. The recorded tv files play on the externder.
I have check drives updates, output setting.
So what do you is wrong?
Your DVR/tv recorder isnt recording sound.
    Hp pavillion a6110n
    amd athlon 64 x2 live! 4400+
    4 gigs 3.3 useable
    generic pnp monitor
    7.2k rpm
    1 linux ubuntu partition
    1 vista partition
    1recovery partition
    1 windows 7 partition
    1linux swap partition
    500W, antc earthwatts EA500
    normal black case
    fans
    saitek cyborg gaming keyboard
    dsl
    2.3 ghz amd
its recording sound, the sound play on the extender, is't also play using the head phones. But will not play sound thru the HDMI cable.
I get sound thru the HDMI cable for Window and if I play AVI file with window player, but if I play DVR-ms file no sound.
    Hp pavillion a6110n
    4 gigs 3.3 useable
    generic pnp monitor
    7.2k rpm
    1 vista partition
    1recovery partition
    normal black case
    fans
    dsl
    2.3 ghz amd
