Usb headset not working in windows 7
chmayurnath
I purchased a new USB headset and when I plugged in for 1st time it worked properly, I could able to hear sound from you tube. and mic was also working properly.
I unplugged the headset and plugged in after a while, head set is not working.
I am able to hear anything except sound like buzzzzzzzzzzzzzzzzzzzz
Please help me out to fix this problem.
Thanks
Welcome to the Forums.
This support trick works quite often. Boot into safe mode. Delete the driver from Device Manager(in this case the headset.) Reboot normally. Windows should reinstall the driver. This technique seems to work more than half the time. It's well worth trying.
    HP Pavilion m9515y
    Phenom X4 9850
    CRT
    750 GB SATA 3G
