My microphone is plugged in but wont even show
substantian
Hello, I have plugged in my microphone and then i go and check to see if its working, but its not even in the recording section of the sound board, and i have checked on other computers to see if it works and it does, and i went to see if the drivers are up to date and it says this
Windows cannot verify the digital signature for the drivers required for this device. A recent hardware or software change might have installed a file that is signed incorrectly or damaged, or that might be malicious software from an unknown source. (Code 52)
so my first reaction was to check drivers and update but this just uses windows drivers so its all up to date, and then i decided to do a system restore and that didn't work so now i'm at a loss and i don't wanna go start deleting stuff and then break even more things.
Note: this all happened after a power outage, it was fine before it and after this is what i got
    Alienware x51
    i5-2320
    8.00 GB
    GeForce GT 545
    NVIDIA High Definition Audio
    LG (not sure which model)
    1920x1080
    1 hard drive
    1TB
    Alienware x51
I did this and even when everything was disabled it still doesn't work but Thank you for trying
    Alienware x51
    i5-2320
    8.00 GB
    GeForce GT 545
    1920x1080
    1 hard drive
    1TB
    Alienware x51
I have windows 7 is this going to work the same way?
    Alienware x51
    i5-2320
    8.00 GB
    GeForce GT 545
    1920x1080
    1 hard drive
    1TB
    Alienware x51
Yes it works the same.
May I suggest that if my solution does not work. Register in our 7 Forum. You would get help more appropriate for your OS.
Windows 7 Help Forums
