Solved pls help new, audio fix, getting new gpu, help im easy step by step process
like is there a download or a repair or something, i got it to load all the way up to open sound mixer, and it said no device installed i followed the normal steps, rundll32 stopped working it like a complete circle, its bugging me and im a hard going gamer vista has great gameing qualities. sorry for spam. it also crashes when you try and open it while it starts up. im pretty sure i did not burn the mulitpliers or the little black thingies its a simi open system, meaning it has no face cover lol.
Go to the start search box and type device manager
go to sound and click on the small +
What shows there?
    Lenovo Thinkpad T400
    LENOVO 64734VM
    Conexant 20561 SmartAudio HD
    15 inch
    1x 180GB Intel 530 series SSD
    1 x 120GB Hitachi 5400rmp
    Medium for New Zealand
    Only ever used a laptop.
    Also use USB Freeview TV Card
    Lenovo Docking Station
    External Speakers
    Other bits a pieces as needed
its been built back up so it can run right, burned itself once, 4200+ dual. its really fast just no sound, and a game with no sound just sucks :(, i aux chucked her in one of the aux jacks, but i have 5 all together and there on a diffrent lay out, so i mean if it is burnt then figuratively speaking i should be able to get the others to work. the register i ran a register test when it went with some nasty sound app, they were there and it showed up but it would not run.
i was on mc, my headphones were going, and i was talking to a server owner during the time, while in the fits if rage we were having i started to chuck at my headphones because they would not work properly, the headphones went soon after and then a bunch of deleted files fallow this, then no sound, problems with sound before this? absolutely. currently, no sound mixer display its grey, and it says the audio service is not running, will not run because rundll32 has stopped. :( now im being bombarded with windows audio endpoint builder has stopped working.
Go to start menu and type cmd
Right click on result and click run as administrator
type rstrui.exe
system restore will start
select a date from before the problem started
edit: press enter after typing rstrui.exe
    LENOVO 64734VM
    15 inch
    External Speakers
try open cmd as above and type
sfc /scannow
press enter
    LENOVO 64734VM
    15 inch
    External Speakers
I don't expect this to fix everything but it will give us the best starting point
    LENOVO 64734VM
    15 inch
    External Speakers
Reboot and run the scan again (up to 3 times) as it will repair more things each time it is run, up to a point.
    LENOVO 64734VM
    15 inch
    External Speakers
OK Sorry I had to go out. What do you mean crashed, did it blue screen?
Can you upload the cbs log please
In cmd as administrator type
findstr /c:"[SR]" %windir%\logs\cbs\cbs.log
or
notepad C:\windows\logs\cbs\cbs.log
1st option would be better
    LENOVO 64734VM
    15 inch
    External Speakers
Note we are in very different time zones and replies might be a while coming
    LENOVO 64734VM
    15 inch
    External Speakers
Thx for the help friend I found a restore point before I was into all the bad stuff?? Anyway, thank you. You are a good friend and I hope you make it to the top. :) :) :) :) you are a great person and you have my blessings.
