Solved System Tray Notification
ColColt
I have a popup problem once again. Each morning I get a notice from the system tray about a blocked program...WinPatrol Change Detection. I have WinPatrol Plus installed but it's been over a year since I had this similar problem and can't remember what I did to stop it. This is what it looks like...
    Dell XPS 435MT
    2.67 gigahertz Intel Core i7 920
    Dell Inc. 0R849J A00
    6G
    ATI Radeon HD 3650
    DELL SP2009W
    SAMSUNG HD642JJ
    640G
    10Mbps
No one knows?
    Dell XPS 435MT
    6G
    ATI Radeon HD 3650
    DELL SP2009W
    SAMSUNG HD642JJ
    640G
    10Mbps
Over 120 views and no one knows...interesting. This place is about as useless as I remember.
    Dell XPS 435MT
    6G
    ATI Radeon HD 3650
    DELL SP2009W
    SAMSUNG HD642JJ
    640G
    10Mbps
Sorry that it took so long for a reply, there is no need to post uncomplimentary remarks, however. A lot of the views are from non members that cannot reply, but are looking for help by reading the posts given to others.
That being said, allow me to try and help. If you boot in clean boot mode, and the problem is no longer present, you
can determine the source of the problem, restoring the programs one by one and testing each time for the problem. Hope this helps
Troubleshoot Application Conflicts by Performing a Clean Startup - Windows 7 Help Forums
If the problem is actually caused by Win Patrol, try setting Win Patrol for a delayed start rather than a start up at boot.
My apologies. Things have been aggravating all the way around and it boiled over to the computer. I've had vascular problems and can't sleep at night more than a couple hours for a week as my foot goes to sleep when I lay down, burns and tingles due to artery blockage. Not anyone's problem but may have been part of the reason for my demeanor.
    Dell XPS 435MT
    6G
    ATI Radeon HD 3650
    DELL SP2009W
    SAMSUNG HD642JJ
    640G
    10Mbps
Sorry to hear that. Lets try to solve the computer problem. Let me know how my suggestions work out.
You can create a start-up Task in "Task Scheduler" for the program and it should bypass Defender.
    Alienware Aurora R4
    Intel Core i7 4960x
    Alienware 0FPV4P
    8GB Corsair 2333MHZ
    GTX 760
    Soundblaster Recon 3D PCie
    Dell U2312HM
    1920x1080
    Samsung 840 PRO SSD
    Alienware Aurora R4 ALX
    Alienware Watercooling
    Alienware Tactx Keyboard
    Alienware Tactx Mouse
    162MB DL 12MB UP
Run the task as an administrator one & then the popup will not appear.
    HP-Pavilion m9280.uk-a
    ASUS NVIDIA Geforce GTS450
    HP w2408 24.0" (Dual monitor)
    1920 * 1200, 1920 * 1200
    BluRay & DVD Weiters
    40 Meg
    Dell XPS 435MT
    6G
    ATI Radeon HD 3650
    DELL SP2009W
    SAMSUNG HD642JJ
    640G
    10Mbps
You can remove winpatrol or change it's settings so that it doesn't alert you about block programs.
    Windows 8.1 Industry Pro x64
    HP Pavillion Elite HPE-250f
    8 gb
    ATI Radeon HD 5770 1 gb ram
    Alienware 25 AW2521HF
    1920x1080 &1680x1050
    1 TB x2
    Dell Poweredge T140
    8GB 2666MT/s DDR4 ECC UDIMM
    1 TB & 360 GB x2
WinPatrol is not the one that's doing the blocking, it's Windows that's blocking WinPatrol Background Change Monitor.
    Dell XPS 435MT
    6G
    ATI Radeon HD 3650
    DELL SP2009W
    SAMSUNG HD642JJ
    640G
    10Mbps
Have you tried my method yet?
    Alienware Aurora R4
    Intel Core i7 4960x
    Alienware 0FPV4P
    8GB Corsair 2333MHZ
    GTX 760
    Dell U2312HM
    1920x1080
    Samsung 840 PRO SSD
    162MB DL 12MB UP
Yes, but got a little stymied when I got to Program/Script. I'll have to wait till I shut down again to see if it works.
That didn't seem to work.
    Dell XPS 435MT
    6G
    ATI Radeon HD 3650
    DELL SP2009W
    SAMSUNG HD642JJ
    640G
    10Mbps
Hi
Look here & try the suggested solution, Run task as an administrator...
WinPatrol Support
    40 Meg
Thank you, sir. That worked!
    Dell XPS 435MT
    6G
    ATI Radeon HD 3650
    DELL SP2009W
    SAMSUNG HD642JJ
    640G
    10Mbps
