32 bit programs can not access internet HELP!
jort84
2
Hey guys I really need some help here. Basically out of the blue none of my 32 bit applications are able to access the internet such as Internet Explorer, FireFox, Steam, etc... IE 64 does work.
This happened 2 days ago and I got frustrated and simply formatted and reinstalled. Now today on this clean install I'm having the same issue! :cry:
I've run numerous hardware test and have determined my hardware is not at fault, I need help guys. How can I fix this what could have caused this?
I have all released updates installed (through built-in windows update) latest drivers for mobo/video/sound/network/etc...
I ran a sfc /scannow and that came back clean, did a check disk and it says it fixed some file system problems but nothing changed with regards to my problem.
System Specs:
Vista 64
A64 4600+
2GB DDR800
250GB Seagate SATA 3.0
Geforce 8800GTX
Using onboard nic card/sound.
Brink
Staff member
mvp
32,202
Location
Oklahoma, USA
System Specs:
Vista 64
A64 4600+
2GB DDR800
Geforce 8800GTX
Hi Jort84,
Welcome to the Vistax64.com forum.
This tutorial will show you how to fix the "Help and Support". Look at the solution for, "The Windows Help (WinHlp32.exe) program is no longer included in Windows".
http://www.vistax64.com/tutorials/87497-help-support-vista.html
  • Show second system?
    Yes
    Operating System
    ASUS Maximus X Code Z370
    Integrated
    3 x 27" Asus VE278Q
    1920x1080
    250GB Samsung 960 EVO M.2,
    256GB OCZ Vector,
    6TB WD Black WD6001FZWX
    Corsair Air 740
    Logitech MX Master
    Creative F200 webcam,
    Linksys EA9500 router,
    Arris SB6190 cable modem,
    APC SMART-UPS RT 1000 XL,
    Lumia 1520 phone
jort84
2
Hi Jort84,
Thank you for taking the time to read my post however, you seem to have completely mis-understood what my problem is.
I do not need nor care for the windows help file. My 32 bit applications can no longer access my internet connection however, my 64 bit programs such as IE 64 can. I need to fix this problem.
Thanks...
Brink
Staff member
mvp
32,202
Location
Oklahoma, USA
Thanks...
Wow Jort84,
I sure did miss what you where asking help on. I must have went blind. (haha) Stayed up to late.
Check and make sure that they are allowed access or added to the exceptions list with the Firewall program. If you are using Windows Firewall, then this tutorial will show you how if needed.
http://www.vistax64.com/tutorials/65334-windows-firewall.html
    Yes
    Operating System
    Integrated
    3 x 27" Asus VE278Q
    1920x1080
    256GB OCZ Vector,
    Corsair Air 740
    Logitech MX Master
    Lumia 1520 phone
ricebus
3
OMG!
This is exactly the same problem I have!
It happend once when I download the beta SP1 for vista, so I reformatted the computer cause I thought the SP I downloaded was corrupted, but it happend again yesterday after I ran Windows Update!
32bit programs can't access the internet althought 64bit ones can access the internet (like IE 64 which I'm using right now).
I checked the firewall thing but it's not the issue.
Also, some 32bit programs keep crashing when I try to run them.
I think it's a problem with the 32bit emulator but I have no idea how to fix it. nor does Google since this is the only relevant link I've found regarding the issue.
HELP? :cry:
Brink
Staff member
mvp
32,202
Location
Oklahoma, USA
Hi Ricebus,
Welcome to the forum. :party:
You might try Resetting IE7 to see if it will help you. You may have a add-on in IE7 that is causing it to not work properly. When you are done resetting, you can enable the add-ons one by one until you find out which one is causing the problem.
In IE7:
1. Click Tools - Internet Options
2. Click Advanced
3. Click Reset
To Enable/Disable the add-ons one by one:
1. Click Tools - Manage Add-ons - Enable or Disable Add-ons
2. Under Show, change this to see the other listings of add-ons.
3. Just dot Enable or Disable at the bottom.
For the other 32 bit programs, you might try running them in Compatibility Mode with XP (SP2) to see if they will run better. This tutorial will show you how.
How to Use Compatibilty Mode in Vista
    Yes
    Operating System
    Integrated
    3 x 27" Asus VE278Q
    1920x1080
    256GB OCZ Vector,
    Corsair Air 740
    Logitech MX Master
    Lumia 1520 phone
Brink
Staff member
mvp
32,202
Location
Oklahoma, USA
#8
Well Ricebus,
I would tell you to do a clean install to fix the problem, but you said you already did that. Since it is happening when you do a Windows Update, I would uninstall that update that you suspect is causing the problem. Once you have it narrowed down to the one(s) that is causing this, I would hide the update so it will not show up in Windows Update anymore. These tutorials will show you how.
How to Uninstall a Windows Update in Vista
How to Hide or Unhide a Windows Update in Vista
    Yes
    Operating System
    Integrated
    3 x 27" Asus VE278Q
    1920x1080
    256GB OCZ Vector,
    Corsair Air 740
    Logitech MX Master
    Lumia 1520 phone
ricebus
3
#9
Uhm brink, I used system restore to reverse the effect of the updates and the problem still exists, so I think it I already tried uninstalling the updates :\
Brink
Staff member
mvp
32,202
Location
Oklahoma, USA
#10
System Restore should have removed it, but you might double check to see if the Update is listed or not to make sure it is uninstalled. See the Uninstall link above for how to see the list.
I do not know what else to try. :confused:
    Yes
    Operating System
    Integrated
    3 x 27" Asus VE278Q
    1920x1080
    256GB OCZ Vector,
    Corsair Air 740
    Logitech MX Master
    Lumia 1520 phone
fionny
2
#11
Seems i had a virus lurking which nod32 did not detect until i ran a restore point. Hidden under an office application
imekrmig.exe
After restore nod32 picked it up and quarantined it and all went well again, not what i initially thought of it being an update from microsoft.
Cheers Guys, hope it helps.
Fionny
fionny
2
#12
Ok seems i was wrong on it being the virus i had picked up, found the solution on another forum somewhere when the problem re-occured for me.
NOD32 seems to be the culprit, turn of http checking in the IMON module job done not sure if this will cure the problem if its already manifested itself but if it hasnt it should prevent it, at least it hasnt come back at me again yet thank god.
Regards,
Fionn
