5308 to 5384
S
Scott S Sikora
Is installation of 5384 over 5308 something that can be done, or is a clean
install the only way to get Beta 2 to install?
Thanks,
Scott
S
Scott S Sikora
By not supported do you mean it will not work or that Microsoft doesn't
recomend or provide support for it?
Thanks
"Andre Da Costa [Extended64]" <[email protected]> wrote in message
news:[email protected]
> Upgrading beta to beta is not supported, clean installs only.
> Andre
> Extended64 | http://www.extended64.com
> Blog | http://www.extended64.com/blogs/andre
> http://spaces.msn.com/members/adacosta
> "Scott S Sikora" <[email protected]> wrote in message
>> clean install the only way to get Beta 2 to install?
>> Thanks,
>> Scott
Z
Zack Whittaker
It's not an available setting in the installer - unless you have a internal
copy of Vista which wasn't released to us, it just won't work.
Zack Whittaker
» ZackNET Enterprises: www.zacknet.co.uk
» MSBlog on ResDev: www.msblog.org
» Vista Knowledge Base: www.vistabase.co.uk
» This mailing is provided "as is" with no warranties, and confers no
rights. All opinions expressed are those of myself unless stated so, and not
of my employer, best friend, Ghandi, my mother or my cat. Glad we cleared
that up!
--: Original message follows :--
> Thanks
>> Andre
>>> Thanks,
>>> Scott
A
The upgrade option will be greyed out.
Andre
> Thanks
>> Andre
>>> Thanks,
>>> Scott
S
Scott S Sikora
Thank you both for your answer.
> Thanks
>> Andre
>>> Thanks,
>>> Scott
Z
Zack Whittaker
Not a prob :o)
Zack Whittaker
that up!
>> Thanks
>>> Andre
>>>> Thanks,
>>>> Scott
A
You are welcome Scott.
Andre
>> Thanks
>>> Andre
>>>> Thanks,
>>>> Scott
