Solved 5670 crashes
fredrick
Hello,
I have two hard drives one with xp 32 and one with vista 64
I bought a new 5670 hd video card . I installed it and it runs ok until I play a video.
every video i play crashes my comp. I installed the latest flash player .latest video drivers.Only way I can play videos is in safe mode,so my guess is that it is a driver issue somewhere. anybody here know of a fix here?
mutch appreciated
    HP-Pavilion m9280.uk-a
    ASUS NVIDIA Geforce GTS450
    HP w2408 24.0" (Dual monitor)
    1920 * 1200, 1920 * 1200
    BluRay & DVD Weiters
    40 Meg
    40 Meg
After installing that,It didn't make any difference.
I didnt unistall my codecs like download recomended though.I tried a yutube video
and when I close my browser I get a blue screen with lines in it or a black screen like my monitor is shut off.I may just start over with a clean install of vista.
I dont really want to rma this video card if all possible.
The card does play games ok ,but my system is a bit old for it.
Do yo0u have a big enough power supply?
What are your system specs?
    Dual L5639 // i7 950 @ 4.0Ghz
    gtx 560 ti // gtx 260-216
    Dual 22" // Headless
I have
n68-s
400 watt
Athlon dual kuma
4 gig ddr2
I read that people were running this card on a 300 watt psu ,the box does say 450 min, 600 for crossfire.
my previous card was a 8400 gs
I bought this 5670 to play diablo3, casual gaming.
On the beta it is a bit taxing to play ,but it looks so much nicer on this card.
A quality 350 would run it, the average 400 shioud run it.
A power supply, like a cx 430, is fairly affordable and easy to swap.
thankyou.
I should get a better supply anyway.
read some forums about this card,and its 2.1 pci
and mayby its not working right on 2.0
I may jhave to get another mobo also.
thank you for your help
take care,
No, pci-e 2.1 is backward to pci-e 1.
It's all good, most likely just to much draw on the psu.
hey,
I just wanted to update that my problem was fixed by disabling hardware acceleration in flash if any one is interested.
I aslo talked to a guy that works on computers and he said I should get a better psu.He didnt want to sell me one or nothing like that. The card works fine now
I bought it open box on neww egg for 50.00 so I was a bit worried,but it looked like a new card.so hopefully its just a bug in fire fox that will be fixed ,i'm not certain.
thanks,
