64 bit Vista Memory
A
Albert Fischer
64 bit Vista will not install if more than 2 megs of memory is installed.
Must install over 2 megs of memory after 64bit Vista is installed.
D
Dustin Harper
What are your system specs? It may be incompatible RAM or mis-configured
BIOS.
Dustin Harper
dharper@xxxxxx | Replace the obvious
http://www.VistaRIP.com | Vista Resource & Information Page
"Albert Fischer" <albertef@xxxxxx> wrote in message
news:un1ncUtVIHA.1204@xxxxxx
C
Colin Barnhorst
Go to the mobo manufacturer's website and determine which brands and speeds
of ram have been tested, especially if you are attempting to use pc6400
memory. Also, use the forum on the mobo manufacturer's website for your
mobo and get some advice. This is a common issue relating to pc6400 ram,
use of the fourth dimm slot, and timings. There is also a MS patch but that
is not a panacea for not using supported ram.
T
Tom Lake
You mean gig, not megs right? 8^) I have 8 GB RAM installed
on an Intel DG965WH motherboard and had no trouble at all
installing Vista 64 Ultimate. There is an issue with my Hauppauge
PVR-500 card where the 64-bit drivers aren't working right yet with
the maximum memory a motherboard can take but other than that,
no problem.
Check your motherboard maker's Website. On some boards,
all four RAM sockets can't be filled. On others (like mine) you
have to use slower than the max RAM speed the motherboard
allows when adding over a certain amount.
Tom Lake
R
Richard G. Harper
It still worked fine for me.
Richard G. Harper [MVP Shell/User] rgharper@xxxxxx
* NEW! Catch my blog ... http://msmvps.com/blogs/rgharper/
* PLEASE post all messages and replies in the newsgroups
* The Website - http://rgharper.mvps.org/
* HELP us help YOU ... http://www.dts-l.org/goodpost.htm
