A few missing .exe's
oondric
I try to create a restore point on my computer. Nothing works.
Here's a picture :D
as you can see, the last 2 tabs (Restore | Remote) are both gone.
i've tried going to The Storage Team at Microsoft - File Cabinet Blog : Why is my System Protection tab missing?, which seemed to be my case.
A customer recently sent us a screenshot of System Properties in Control Panel showing that his System Protection tab was missing. Launching the tab by its executable, SystemProtectionProperties.exe, did not launch the tab, either.
In this case, the customer’s IT group had disabled System Restore using Group Policy. You can check whether this is the case by looking in the registry for HKEY_LOCAL_MACHINE\Software\Policies\Microsoft\Windows NT\SystemRestore\DisableSR. If that value exists and is non-zero, then System Restore is completely disabled and you won’t see the System Protection tab.
The problem is, i dont have the SystemRestore folder in WindowsNT.
it seems my computer is allergic to system restores .__.
And SystemPropertiesProtection.exe doesnt launch the tab. It opens the System Properties window (above)
Thanks (:
J
Jon
Might be a per user setting eg something under
HKEY_CURRENT_USER\Software\Policies\Microsoft\Windows NT\SystemRestore\
as opposed to the machine wide settings. A thorough search of the registry
for 'DisableSR' ('Edit > Find' from the regedit menus, after clicking on
'Computer') may turn up fruit elsewhere.
Jon
"oondric" <[email protected]> wrote in message
news:[email protected]
> I try to create a restore poit on my computer. Nothing works.
> Here's a picture :D
> [image: http://i44.tinypic.com/25s0dw9.jpg]
> i've tried going to 'The Storage Team at Microsoft - File Cabinet Blog
> : Why is my System Protection tab missing?'
> (http://blogs.technet.com/filecab/archive/2007/04/09/why-is-my-system-protection-tab-missing.aspx),
> which seem'ed to be my case.'
>> the tab, either.
>> Protection tab.
> [image: http://i43.tinypic.com/2i11nvd.jpg]
> Thanks (:
> oondric
