A sound problem
J
Jimshirl29
I have installed the drivers for a sound card I have called 24-Envy24 Family
Controller. It is compatible with Vista and everything works fine, but when
I boot up again it loads a High Definition Audio Device which doesn't work
and I uninstalled but keeps coming back.
Any suggestions?
J
John Barnes
Have you checked in the BIOS to see if you turned off the MOBO sound. Often
you have problems if both are enabled.
"Jimshirl29" <jimshirl29@xxxxxx> wrote in message
news:%23afKC4MSJHA.3300@xxxxxx
>Family Controller. It is compatible with Vista and everything works fine,
>but when I boot up again it loads a High Definition Audio Device which
>doesn't work and I uninstalled but keeps coming back.
> Any suggestions?
