Access information stored on old Hard Drive
murr
Hey all,
I have recently bought a new HP and wanted to get all the information transfered from my old hard drive to my new one. I cannot seem to do this tho because it will not give me the permissions to access the folders on the old hard drive. Is their a way I can access this information through an admin account? I have tried to dual boot but I cannot get into the old partition and it gives the blue screen of death on the old hard drive partition (running XP operating system). Any help on this matter would be most appreciated.
johngalt
Antidisestablishmentarian
Hmmm - I just did this from my old Vista x64 partition to my new Vista x64 partition - and had no problems (copying info that is).
However, trying to boot your old XP partition in your new comp is not going to work - the mobo, and other hardware, drivers are just going to be too different for XP to be able to cope.
Are you running Windows Explorer with the "Run as Administrator" enabled (find windows explorer in start and right click, then select "Run as Administrator" - because you will need full admin privileges to do so).
If that does not work, then here is an idea - on your new computer, try creating a new user - that has the exact same username and password as the user on the XP partition (and make sure it is not a limited user - IOW, it is an administrator account). Now change (not switch users but actually log out of your current user and log into the new user) and see if you can copy the info. If you can, then you'll want to copy every thing to your 'public' folders (create folders in C:\Users\Public) so that you can boot back into your other account and still get access to them.
    The Beast Model V
    eVGA X58 Classified3
    3 * 4GB Mushkin Enhanced Redline CL7 DDR3 1600 MHz (PC3-12800)
    eVGA GTX 970 + eVGA GTX 560 Ti 448 Core Calssified (PhysX)
    Realtek HD Audio (onboard)
    2 * Lenovo LT2323pwA
    2 * 1920 x 1080
    2 * Seagate Barracuda 7200.12 ST31000528AS 1TB 7200 RPM SATA II
    Seagate Barracuda 7200.12 ST1500DL001 1.5 TB SATA II
    ThermalTake BlackWidow 850W
    ThermalTake Level 10 GT
    Corsair H100 (CPU) + Air (2 * 210 mm + 3 * 120mm fans)
    Logitech MX Master
    Logitech G15 (gen 2)
    180 Mbit down / 15 Mbit up
    3 VMs built off IP 14971:
    UUP disabled / single VHD | UUP disabled / dual VHDs with moved \User Tree | UUP enabled / single VHD
Bare Foot Kid
R.I.P. August 13th 2014
    * BFK Customs *
    Intel C2Q 9550 Yorkfield
    ASUS P5Q Pro
    8GB Dominator 8500C5D
    XFX ATI 1GB 4870 XXX
    Realtek HD 7-1
    1920x1080P & 1920x1200
    Corsair 620HX
    CM Cosmos RC-1000
    Razer Diamondback 3G
    HP Enhansed Multimedia
    18.6Mb/s
    My First Build ;)
Disable UAC and reboot. Then take ownership of the all folders in the sub container from the root of the drive.
    16GB DDR667
    SAS RAID
murr
Ok well taking the UAC and disabling it worked great! I was able to take complete ownership of the files and have it work! I did have to do this under the admin account tho that is only available through cmd prompt.
Thanks all!
