This has been VERY helpful, thank you. We've been having exactly the same
problems after just upgrading from XP Home to Vista Ultimate and tons of
Access Denied errors which are explained here and hopefully will help us
resolve our same issues.
It now makes us wonder if we won't also then get the same Access Denied
errors when we attempt to try Printer Sharing with a Lexmark X83 (unsupported
in Vista since Lexmark hasn't / won't release driver updates). We
uninstalled/moved the X83 printer to the other XP system where it works, and
curious if diverting prints fromt the Vista system to the XP Lexmark printer
system will be OK. Can't find a clue in many queries.
Again, thanks for helping us find the DOCUMENTS/MY DOCUMENTS WORKAROUNDS
If the My Documents, My Music, My Pictures, and My Videos links in the Start
menu do not point to the Documents, Music, Pictures, and Videos folders, you
must manually redirect these links to the correct folders. To redirect these
links, follow these steps: 1.Click Start, right-click the link, and then
click Properties.
2.On the Location tab, replace the wrong target location with the correct
target location. For example, to redirect the My Music folder to the Music
folder in Windows Vista, enter %systemdrive%\Users\user_name\Music.
3.Click Apply.
"Malke" wrote:
> bassjace wrote:
> > HI,
> > I have Vista Ultimate and am looking around the software and am getting
> > plenty of Access is Denied error messages when I try and click on folders in
> > the C: directory that you could browse in XP.
> > eg I have enabled show hidden files and folders, and known extension types
> > and unhid protected operating files. Under C: Users -my user- I wanted to
> > look at Application data and local settings but cannot, Access Denied Data
> > not accessible. Even My Documents which has the little shortcut arrow is the
> > same.
> > What gives? I am the Admin on the machine, I have enabled the UAC and tried
> > it without, still the same.
> > I want/like to be able to look at my files and folders, why am I being told
> > NO????
> It sounds like you are trying to look at junctions instead of real
> directories. There is no "My Documents" in Vista, just a junction to the
> Documents directory. There are also a lot more protected directories in
> Vista such as Program Files, etc. Do some reading at the links below to
> familiarize yourself with the changes in Vista.
> From MVP Jimmy Brush - "Many folders used by earlier versions of
> Windows have been moved to a new location or given a new name in Windows
> Vista. However, the old folders can still be seen if you have enabled
> Show Hidden Files. Notice they are displayed with a transparent icon
> and a shortcut symbol.
> "Although these look like folders, they are actually what is known as a
> junction. Junctions behave like shortcuts, but look just like regular
> folders. Their purpose is to silently redirect programs that access them
> to their Windows Vista equivalent.
> "Since junctions aren't really folders, it is not possible to access
> them, and any attempt to do so will give you an "Access Denied" error."
> Changes to the built-in administrator account in Vista
> http://support.microsoft.com/Default.aspx?kbid=942956
> http://www.jimmah.com/vista/
> http://www.jimmah.com/vista/Security/junctions.aspx
> http://www.realtime-vista.com/general/2007/04/access_denied_to_documents_and.htm
> Malke
> Elephant Boy Computers
> www.elephantboycomputers.com
> "Don't Panic!"
> MS-MVP Windows - Shell/User
