Accidentally disabled my speakers
A
Aberfox
In the sound pop up from the control panel I was trying to change the default
speaker, but accidentally disabled it. Now the speaker has disappered from
the playback devices tab and I cannot get any sound out of my speakers.
Q. How do I enable my speakers again?
PS. Its a laptop, so I think it's the internal speakers I've disabled
A
Aberfox
Yey that worked, and it was so simple.
Taa very much.
"Cal Bear '66" wrote:
> Right click in the Playback window and check both "Show Disabled Devices" and
> "Show Disconnected Devices".
> I Bleed Blue and Gold
> GO BEARS!
> "Aberfox" <Aberfox@xxxxxx> wrote in message
> news:E34A1786-EA3C-4D7D-BED2-B41035DE0B34@xxxxxx
R
Rodney Farmer
Have you tried reverting the system to a System Restore point to a date
prior to your problem?
Rod Farmer
> default
K
KAWAN
W
Wandering
"KAWAN" <KAWAN@xxxxxx> wrote in message
news:0F6CE1DC-2687-4375-A60B-D393A7421B15@xxxxxx
>> default
>> from
I think you meant the popup from the task bar or system tray. So, open
Control Panel, Look for the audio controls for your sound system, and open
it. You should be able to adjust just about anything. Also, some laptops
have a Fn key combination to mute the speakers, make sure you check that and
that they are not muted.
Good luck.
K
KAWAN
jasons
1
I'm having a similar problem, but none of these solutions appears to work. When I go to the sound settings on the control panel, it simply reads "no audio devices installed." There are no devices to click on to install. When I right click the sound icon in the system tray there is no option for enabling or reinstalling audio devices. :mad::cry:
noobito
1
#8
Ok go back into control Panel and then sound and in the playback tab, u just need to right click in the box and select show disabled devices and u should then be able to see the speakers u disabled.
hope this helps
noobito
oops srry din;t see the answers was posted above
