Account Control Issue
J
JD Brown
I have a program (Linksys VOiP) that needs to load upon initial startup, but
it is "blocked" by the account control until I physically allow it as the
administrator. Does anyone know of a way for Vista to recognize program
signatures that are routinely loaded so that the startup feature works as it
is supposed to?
I realize that account control cannot be disabled, and the Linksys program
is already authorized to run as administrator and has a valid MS digital
signature....not sure why it is being blocked.
JB
.Joe
1337 spammer
912
Location
127.0.0.1
is supposed to?
JB
JB:
The UAC (user account control) is an integrated security feature of Vista. It is not recommended that you disable it. If, however, you are comfortable with running Vista without a major security feature, you can read this tutorial on how to enable/disable the UAC: http://www.vistax64.com/tutorials/48893-user-account-control-uac.html
I hope this helps.
    Intel Q6600 Quad Core 2.4 Ghz
    Dell 0TP406
    Nvidia 8800 GT 512 MB
    Dual Dell 22" Widescreen
    3360x1050
    320 GB Internal Main
    500 GB USB External
    160 GB USB External
    2TB USB External
    DSL 3MB
R
Ronnie Vernon MVP
JD
The best solution for this problem, without disabling any security
components, is to use the Task Scheduler to creat a task that starts the
program when you log on. This task can be run with highest privileges and no
prompt from the User Account Control.
See the following website for instructions and a small utility that
automates creating the scheduled task.
How do I run an administrative program (that needs my permission to start)
every time I log in and prevent the "Windows has blocked some startup
programs" message?:
http://www.jimmah.com/vista/Administration/autostart_admin_program.aspx
Ronnie Vernon
Microsoft MVP
Windows Desktop Experience
"JD Brown" <JDBrown@xxxxxx> wrote in message
news:6E230EA4-4405-4819-B18B-1BD05CBB0ED3@xxxxxx
>but
> it
> is supposed to?
> JB
