Acrobat 8
G
Gustavo
I 've just got my new computer. When I tried to open a PDF file the message
was "Runtime error" and I had to close the file. Windows suggested to update
Acrobat. I downloaded the last version. Still getting the same message over
and over. Any clue? Is this a Adobe or Vista problem?
Thanks
Gus
P
philo
"Gustavo" <Gustavo@xxxxxx> wrote in message
news:96F6AE19-F8B0-4147-85F0-D0F763D824DB@xxxxxx
message
update
over
> Thanks
> Gus
Who knows?
Try Foxit instead of Adobe
http://www.foxitsoftware.com/pdf/rd_intro.php
P
PNutts
There is a possibility that it is the file itself. Can you open Reader from
the menu without opening a file?
With that said, I've run every Vista compatible version of Reader without
issues. The current version is 8.1.1. If yours is lower than that, you should
go ahead and upgrade.
Good luck.
> Thanks
> Gus
>>>Try Foxit instead of Adobe<<<
No No, don't Try it....install and Use it :>)
Far better program than that BloatWare Adobe Reader 8
All the best,
SG
"philo" <philo@xxxxxx> wrote in message
news:OHqOQ9SZIHA.4684@xxxxxx
> message
> update
> over
>> Thanks
>> Gus
> Who knows?
C
The FoxIt reader is phenomenal and lightweight. So good that I have
purchased some of their other pdf application. They are all really
good. These people knows pdf better than Adobe! :)
//ceed
