ActiveX Control will not install in Internet Explorer
shortmantuff
My computer won't install ActiveX Control on Internet Explorer. Any suggestions?
    Toshiba Satellite A215-S4757
    2048MB DDR2 SDRAM
    ATI Radeon® X1200 128MB-319MB
    15.4” diagonal widescreen TruBrite®TFT LCD display at 1280x800 native resolution (WXGA)
    250GB (4200RPM); Serial ATA hard disk drive
Brink
Staff member
mvp
From PM said:
Thanks. I figured out how to get it to work, I just allow everything to install ActiveX Control, but this is a Security Threat so I wish it would just install ActiveX Control when I wanted it to. Are the links at the bottom of the forum you moved me to where I should look how to fix that?
Hi Shortmantuff,
Is there a option for Prompt instead of Enable in the Internert Properties, Security tab, Custom level button for Internet zone (top).
    3 x 27" Asus VE278Q
    1920x1080
    1TB Samsung 970 EVO Plus M.2,
    250GB Samsung 960 EVO M.2,
    6TB WD Black WD6001FZWX
    Logitech MX Master
    Linksys EA9500 router,
    Arris SB8200 cable modem,
    Lumia 1520 phone
shortmantuff
Yes. I did enable because when I clicked Install ActiveX Control, it wouldn't install it, so I couldn't do what I wanted to do (I want to run an online scan). But when I enabled "Download signed ActiveX controls" I could run the scan. I was wondering why I am not able to download ActiveX control using prompt but when I enable it, it downloads.
    2048MB DDR2 SDRAM
Brink
Staff member
mvp
    3 x 27" Asus VE278Q
    1920x1080
    Logitech MX Master
    Lumia 1520 phone
