Unsure. I ran into a different issue but got this error. It turns out
there was a x64 print driver living in the x86 driver location so when a new
x86 client connected it failed with the 0x000000c1 error.
Is this 64bit or 32bit?
I assume you hit this error almost immediately
the explorer process will load printui.dll which drives Add Printer
You can launch Add Printer without explorer by opening a command prompt and
typing
rundll32 printui.dll,PrintUIEntry /il
or for Network Add Printer
rundll32 printui.dll,PrintUIEntry /ip
Here is the list of files loaded and referenced by other files when starting
Add Printer using rundll32. Any one could be the issue but I sorted the
spooler components and placed them at the top of the list.
spooler
ModLoad: 71670000 716b2000 C:\Windows\system32\WINSPOOL.DRV
ModLoad: 73860000 73938000 C:\Windows\system32\printui.dll
ModLoad: 740a0000 740cc000 C:\Windows\system32\puiapi.dll
ModLoad: 740f0000 74127000 C:\Windows\system32\ntprint.dll
ModLoad: 70fd0000 70fe2000 C:\Windows\system32\tcpmonui.dll
other stuff
ModLoad: 004b0000 004be000 rundll32.exe
ModLoad: 76f40000 77067000 ntdll.dll
ModLoad: 76cb0000 76d8b000 C:\Windows\system32\kernel32.dll
ModLoad: 77100000 7719d000 C:\Windows\system32\USER32.dll
ModLoad: 770b0000 770fb000 C:\Windows\system32\GDI32.dll
ModLoad: 76a90000 76b56000 C:\Windows\system32\ADVAPI32.dll
ModLoad: 76970000 76a33000 C:\Windows\system32\RPCRT4.dll
ModLoad: 759b0000 75a5a000 C:\Windows\system32\msvcrt.dll
ModLoad: 76790000 767b9000 C:\Windows\system32\imagehlp.dll
ModLoad: 72f30000 72f4e000 C:\Windows\system32\ShimEng.dll
ModLoad: 755c0000 755ec000 C:\Windows\system32\apphelp.dll
ModLoad: 6cbd0000 6cc58000 C:\Windows\AppPatch\AcLayers.DLL
ModLoad: 75c70000 7677f000 C:\Windows\system32\SHELL32.dll
ModLoad: 757c0000 75818000 C:\Windows\system32\SHLWAPI.dll
ModLoad: 76b60000 76ca4000 C:\Windows\system32\ole32.dll
ModLoad: 75af0000 75b7d000 C:\Windows\system32\OLEAUT32.dll
ModLoad: 75670000 7568e000 C:\Windows\system32\USERENV.dll
ModLoad: 75650000 75664000 C:\Windows\system32\Secur32.dll
ModLoad: 751c0000 751d4000 C:\Windows\system32\MPR.dll
ModLoad: 75c50000 75c6e000 C:\Windows\system32\IMM32.DLL
ModLoad: 76820000 768e8000 C:\Windows\system32\MSCTF.dll
ModLoad: 77070000 77079000 C:\Windows\system32\LPK.DLL
ModLoad: 768f0000 7696d000 C:\Windows\system32\USP10.dll
ModLoad: 743c0000 7455e000
C:\Windows\WinSxS\x86_microsoft.windows.common-controls_6595b64144ccf1df_6.0.6001.18000_none_5cdbaa5a083979cc\comctl32.dll
ModLoad: 71a80000 71ab5000 C:\Windows\system32\ACTIVEDS.dll
ModLoad: 71a40000 71a73000 C:\Windows\system32\adsldpc.dll
ModLoad: 75340000 753b5000 C:\Windows\system32\NETAPI32.dll
ModLoad: 75720000 75727000 C:\Windows\system32\PSAPI.DLL
ModLoad: 767c0000 7680a000 C:\Windows\system32\WLDAP32.dll
ModLoad: 77080000 770ad000 C:\Windows\system32\WS2_32.dll
ModLoad: 76780000 76786000 C:\Windows\system32\NSI.dll
ModLoad: 71a10000 71a3e000 C:\Windows\system32\credui.dll
ModLoad: 74890000 748a4000 C:\Windows\system32\ATL.DLL
ModLoad: 723e0000 723e8000 C:\Windows\system32\CFGMGR32.dll
ModLoad: 75820000 759aa000 C:\Windows\system32\setupapi.DLL
ModLoad: 73d00000 73d32000 C:\Windows\system32\WINMM.dll
ModLoad: 739b0000 739e9000 C:\Windows\system32\OLEACC.dll
ModLoad: 74930000 7493a000 C:\Windows\system32\WTSAPI32.dll
ModLoad: 75080000 750ba000 C:\Windows\system32\slc.dll
ModLoad: 74f40000 74f48000 C:\Windows\system32\VERSION.dll
ModLoad: 75020000 75039000 C:\Windows\system32\IPHLPAPI.DLL
ModLoad: 74fe0000 75015000 C:\Windows\system32\dhcpcsvc.DLL
ModLoad: 75260000 7528c000 C:\Windows\system32\DNSAPI.dll
ModLoad: 74fd0000 74fd7000 C:\Windows\system32\WINNSI.DLL
ModLoad: 74fa0000 74fc1000 C:\Windows\system32\dhcpcsvc6.DLL
ModLoad: 73940000 739a2000 C:\Windows\system32\mscms.dll
ModLoad: 6cc80000 6cce9000 C:\Windows\system32\irprops.cpl
ModLoad: 72a20000 72a27000 C:\Windows\system32\WSOCK32.dll
ModLoad: 74940000 7494f000 C:\Windows\system32\nlaapi.dll
ModLoad: 75200000 75218000 C:\Windows\system32\ntdsapi.dll
ModLoad: 74db0000 74deb000 C:\Windows\system32\mswsock.dll
ModLoad: 749e0000 749e5000 C:\Windows\System32\wshtcpip.dll
ModLoad: 74f50000 74f55000 C:\Windows\System32\wship6.dll
ModLoad: 74940000 7494f000 C:\Windows\system32\NLAapi.dll
ModLoad: 73b20000 73b28000 C:\Windows\System32\winrnr.dll
ModLoad: 73b30000 73b3f000 C:\Windows\system32\napinsp.dll
ModLoad: 73a00000 73a06000 C:\Windows\system32\rasadhlp.dll
ModLoad: 74f70000 74f77000 C:\Windows\system32\credssp.dll
ModLoad: 750c0000 751b1000 C:\Windows\system32\CRYPT32.dll
ModLoad: 75220000 75232000 C:\Windows\system32\MSASN1.dll
ModLoad: 74bc0000 74c04000 C:\Windows\system32\schannel.dll
ModLoad: 74e30000 74eac000 C:\Windows\system32\kerberos.dll
ModLoad: 75290000 752a1000 C:\Windows\system32\cryptdll.dll
ModLoad: 74eb0000 74ef5000 C:\Windows\system32\bcrypt.dll
ModLoad: 75a60000 75ae4000 C:\Windows\system32\CLBCatQ.DLL
ModLoad: 6fb60000 6fb74000 C:\Windows\system32\shgina.dll
ModLoad: 75240000 75251000 C:\Windows\system32\SAMLIB.dll
ModLoad: 73750000 737d5000
C:\Windows\WinSxS\x86_microsoft.windows.common-controls_6595b64144ccf1df_5.82.6001.18000_none_886786f450a74a05\comctl32.dll
ModLoad: 74860000 74890000 C:\Windows\system32\DUser.dll
ModLoad: 748b0000 748ef000 C:\Windows\system32\UxTheme.dll
ModLoad: 74130000 7415f000 C:\Windows\system32\xmllite.dll
ModLoad: 6cfd0000 6d0c9000 C:\Windows\system32\bthprops.cpl
ModLoad: 74300000 7432d000 C:\Windows\system32\WINTRUST.dll
Alan Morris
Windows Printing Team
Search the Microsoft Knowledge Base here:
http://support.microsoft.com/search/?adv=1
"Rick_Hugh" <
[email protected]> wrote in message
news:
[email protected]
> Ok.....so, how would I got about attempting to correct this?
> Thanks
> "Alan Morris [MSFT]" wrote:
>> the error the UI component is reporting is bad exe format. This will
>> also
>> apply to dlls. Is sounds like x86 binaries are loading on x64 or x64
>> binaries are loading on x86.
>> E:\>winerror 0x000000c1
>> 193 ERROR_BAD_EXE_FORMAT <--> 0xc000000a STATUS_BAD_INITIAL_PC
>> Alan Morris
>> rights.
>> "Rick_Hugh" <[email protected]> wrote in message
>> news:[email protected]
>> > No.
>> > "Bob" wrote:
>> >> Do you see the printer in Device Manager?
>> >> *Report back, please*
