Adjust Glass Color
Brink
Staff member
mvp
TweakVista.com - Change color of glass with regedit (with decimal to hex ARGB converter)
Does any body understand what to do for step 3 of this tutorial
Cheers Dave
Hi Dave,
3. Restart DWM with net stop uxsms followed by net start uxsms at command prompt.
It just means to open a command prompt window and type the commands in bold to Stop and Start the Desktop Window Manager Session Manager (DWM) service. You can instead, logoff and logon, or restart the computer for the same affect as this step 3.
    3 x 27" Asus VE278Q
    1920x1080
    250GB Samsung 960 EVO M.2,
    256GB OCZ Vector,
    6TB WD Black WD6001FZWX
    Logitech MX Master
    Linksys EA9500 router,
    Arris SB8200 cable modem,
    Lumia 1520 phone
Brink
Staff member
mvp
David,
If all you want to do is to adjust the transparency, you can just change the "Color Intensity" levels in step 3 of this tutorial to how you like it. For what you want, just slide it a bit more to the left.
http://www.vistax64.com/tutorials/83824-color-scheme.html
    3 x 27" Asus VE278Q
    1920x1080
    256GB OCZ Vector,
    Logitech MX Master
    Lumia 1520 phone
Brink
Staff member
mvp
Glad to hear it David.
    3 x 27" Asus VE278Q
    1920x1080
    256GB OCZ Vector,
    Logitech MX Master
    Lumia 1520 phone
