Adjusting Vista's Lock settings
W
wolverinegod
I, as I assume many others, am extremely frustrated with my computer
locking after a very short period of sitting idle. I have looked
everywhere for a place to adjust the amount of time i have before
windows locks. Does anyone know how to do this? I'm running Ultimate.
D
Don Varnau
Change your Screensaver settings.
Right-click the desktop> Personalize> Screensaver. Change the time before
the screensaver comes on and/or uncheck "On resume, display logon screen."
Don
[MS MVP- IE]
"wolverinegod" <wolverinegod@xxxxxx> wrote in message
news:333ec73e-8937-4b48-8671-58cb8ed3a9ff@xxxxxx
W
wolverinegod
On Feb 20, 5:15 am, "Don Varnau" <don_04[at]varnau[dot]org> wrote:
> Hi,
> Hope this helps,
> Don
> [MS MVP- IE]
> "wolverinegod" <wolverine...@xxxxxx> wrote in message
My screen saver runs fine, the problem is the computer will lock
eventually - i don't want to disable it, just adjust how long until it
locks.
D
Don Varnau
> > Hi,
before
screen."
news:13dd3635-a2d2-45e9-858d-e40f351dcab2@xxxxxx
> locks.
Assuming that you *do* want the computer to lock automatically...
Go to Control Panel> Power Options and experiment with sleep settings. You
can set sleep to occur sometime after the screensaver comes on and require a
password on wakeup.
Then, go to screensaver settings and uncheck "On resume, display logon
screen."
I don't know of another method, unless there's a third-party program
available.
Don
[MS MVP- IE]
W
wolverinegod
> > > Hi,
> before
> screen."
> > locks.
> Hi,
> password on wakeup.
> screen."
> available.
> Don
> [MS MVP- IE]
Thanks Don, that sounds like my best bet.... i'm surprised there isn't
a setting for locking the computer.... but this is a good start.
