adminpak.msi for Vista?
G
Guest
I want to upgrade my WinXP Pro to Vista RC1, but I tested in the lab and it
removes the Admin tools. I have a 2000 AD. The only way I know to get AD
admin tools (AD Users and computers, AD Sites/Services, etc.) is to actually
set up Longhorn Server, the make it a DC, then use the tools installed to
administer the other domain. Is there any other way?
T
Tom Ziegmann
Currently the only way to get the Server 2003 adminpak to work on Vista is
to modify the MSI file. If you search Google you can find the directions.
BTW..after RTM, Microsoft is going to work on an AdminPak for Vista.
Tom Ziegmann
Microsoft Certified Professional
Windows Vista / Server Longhorn TechBeta Tester
Windows Server 2003 SP2 TechBeta Tester
<-> wrote in message news:ufGsrqM3GHA.4388@TK2MSFTNGP03.phx.gbl...
>actually set up Longhorn Server, the make it a DC, then use the tools
>installed to administer the other domain. Is there any other way?
K
Keith
You do not want to upgrade windows XP to Vista RC1 unless you have a whole
in the head. Get a used 2.0 GHz computer w/ 512 MB and 128 MB ATI or Nivida
card to test run it on. I picked one up for $100 used.
R
>>it removes the Admin tools. I have a 2000 AD. The only way I know to get
>>AD admin tools (AD Users and computers, AD Sites/Services, etc.) is to
> Nivida card to test run it on. I picked one up for $100 used.
Why not? Care to explain your reasoning? You buy a used computer, so
install XP on that and upgrade it. I don't understand the connection you're
making between upgrading XP and getting another computer.
Rock [ MVP User/Shell]
F
Frank Saunders, MS-MVP OE/WM
"Rock" <rock@nospam.net> wrote in message
news:uxuXf7d4GHA.3400@TK2MSFTNGP04.phx.gbl...
>>>get AD admin tools (AD Users and computers, AD Sites/Services, etc.) is
>>>to actually set up Longhorn Server, the make it a DC, then use the tools
>> whole in the head. Get a used 2.0 GHz computer w/ 512 MB and 128 MB ATI
>> or Nivida card to test run it on. I picked one up for $100 used.
> you're making between upgrading XP and getting another computer.
Because one should never upgrade their main machine (the one with important
data) to a beta, especially a beta operating system.
http://www.fjsmjs.com
Answer in newsgroup. Don't send mail.
R
"Frank Saunders, MS-MVP OE/WM" <franksaunders@mvps.org> wrote in message
news:B4A536B8-C80E-4968-9D65-6D32631D0395@microsoft.com...
> important data) to a beta, especially a beta operating system.
Frank I understand that. But he didn't clarify it. His statement, without
any clarification, makes no sense. The OP was talking about a test
environment.
