Adobe Air...what is it?
I just activated Adobe Reader 9 and it came with Adobe Air as a separate item in programs list. My home laptop is mainly for entertinment (games, mail, vista forum, (?)porns, etc.. ) Serious business computing is always done by secretaries in the office.
I cannot understand all the blogs about it on the net. What is it and do I need it?
    HP Pavilion dv7-1170us
    Intel Core 2 Duo T5800 @ 2.00GHz
    Compal
    NVIDIA GeForce 9600M GT
    1440 x 900
    289.09 GB
    Synaptics PS/2 Port TouchPad
    IBM enhanced (101-or 102) keyboard
    cable Wireless
    HP Compaq Presario/SR5113WM
    AMD Athlon 64 X2 3600+ 1.9Ghz
    Asus M2N68-LA
    PNY Nvidia 8400 GS 256MB
    On board RealTek
    Acer X163W LCD
    1366x768
    7200 rpm
    Western Digital 160 GB IDE
    Dynex 400w
    Nothin Special
    Stock
    Wireless Logitech LX7
    Comcrap 10mb cable
Mansrm81, thanks for the link but I have come across it already plus a dozen other blogs andf I am still clueless.
All that I seem to understand is it is mainly for "developer" which I am sure I am not (because I have no clue what a developer is). I just want a simple clear advice on whether or not I should keep it (because I am liable to use it) or delete (because I probably will never use it?). BTW, it is downloadable separately (and free). Hence, I can easily delete and re-install except I really do not know what it is used for.
    Compal
    1440 x 900
    289.09 GB
    cable Wireless
I don't know what to say its just another piece of bloatware and I uninstalled it cause it was no use to me.
    Asus M2N68-LA
    On board RealTek
    Acer X163W LCD
    1366x768
    7200 rpm
    Dynex 400w
    Nothin Special
    Stock
    Comcrap 10mb cable
Airbot
You don't need it. Extra bull. I uninstalled it when I downloaded adobe. All I use is adobe reader, shockwave,flash. I don't use acrobat. adobe reader works fine without it for the basic use if that's all you need.
    Airbot 2.0
    EVGA Nvidia GTX 480 -Fermi
    ASUS Xonar D2X
    1920x1080@60hz
    1 OCZ Vertex2 180GB SSD
    Pioneer DVD Burner DVR-S18M
    Corsair HX1000W
    Cooler Master HAF 932
    Logitech Wireless MK700
    Windows 7
    W.E.I final score= 7.7
    Windows Vista=5.9
Thanks, airbot and mansrm81. It's gone!
    Compal
    1440 x 900
    289.09 GB
    cable Wireless
smarteyeball
Eye know, eye know
Yep, it's just another reason to dislike Adobe products.
    i7 3770K HT ON 4.7GHz
    P8Z68 Deluxe Gen 3
    8GB G.Skill Ripjaws X 2133mhz
    X-FI Forte + ATH-AD900
    1920*1200 / 1920x1080
    Corsair AX1200W
    Lian Li PC-V1020A
    Laptop Specs:
    Clevo Sager P170HM //
    17.3 Matte 1920x1200 //
    i7 2720QM // 8GB 1333mhz //
    Dedicated GTX 485M //
    Samsung Story 2TB USB 3.0
stormy13
Might want to do yourself a favor and remove Reader all together and give this a try,
Foxit Software
Much lighter on resources, more options out of the gate, and opens almost instantly.
    Me
    Athlon x2 7750 BE
    Asus M4A78 Pro
    2x2gb Kingston
    Sapphire HD 4830
    X-Fi Xtreme Music
    Acer P221w and Acer 1916w
    1680x1050 and 1440x900
    Antec Earthwatts 500W
    Antec Sonata III
    Logitech G5 v2
    Logitech Wave
#9
I agree, FOXIT is much better ...smaller, simpler and faster. I've been using it for a year now.
But guess what, I just found out some free porn sites require Adobe Media Player which requires Adobe air. (I regret posting this). Thus, I had to re-install it. And then I notice it has no size listed in Add/remove. What does it mean when a downloaded third party program has no size?
    Compal
    1440 x 900
    289.09 GB
    cable Wireless
smarteyeball
Eye know, eye know
Lol, at least you found a use for AIR ;)
No size reported isn't too big a deal. I have a printer driver that doesn't report size either. It's probably just not added into the code to report size, or it uses a different installer that doesn't report.
    P8Z68 Deluxe Gen 3
    Corsair AX1200W
    Lian Li PC-V1020A
    Laptop Specs:
