Adobe Flash player 64 bit?
211
Location
Reading PA
Is adobe flash player available for 64-bit browsers? I have been recently using 64 bit Internet Explorer and I cant use programs like Cafe World on Facebook. Any suggestions if any exist???
Thanks.
    HP Pavilion DV7-1129wm Entertainment PC
    AMD Turion X2 RM-72 Dual Core @ 2.1GHz
    2 x 2 GB Hyundai DDR2 400 MHZ
    ATI Mobility Radeon HD 3200 @ 256 MB
    IDT High Definition Audio/SRS Premium Sound/Altec Lansing
    17" Laptop Screen
    1440 x 900 laptop, external 17 in LCD 1024 x 768
    WD Scorpio Blue 320 GB SATA 5400 RPM
    Toshiba 68 GB SATA 5400 RPM Second Drive (backup)
    8 Cell Lithium Ion Battery
    Laptop with "light up" HP Logo on outside
    Insane air coming out of Targus dual fan cooler
    Microsoft Wireless Mobile Mouse 3000 / Touchpad
    Full Keyboard with numpad
    Comcast Cable 20 MBps
    Used Primarily for CAD design using SolidWorks 2010.
    Also I love to watch HD movies using the HDMI output(Netflix).
    Linked to my Xbox 360 for Windows Media Center
    3 USB ports + USB/eSata
    HP Remote for Windows Media Center and Quickplay
    Internal Dual Layer DVD+/-RW
    External HP Lightscribe Dual Layer DVD+/-RW
    HP Webcam and Microphone
93
Location
United Kingdom
    Wired2fire custom evolution
    Core2Extreme X6800 @ 2.93ghz
    Nforce 4 SLI 16x
    Corsair DDR2 800mhz x 4gb
    XFX Nvidia 260gtx SLI
    Soundblaster Audigy 4
    Dell 24inch
    1920x1200
    Western Digital Cavier 500gb
    Western Digital Raptor 150gb
    Tagan Turbojet 950w
    Silverstone Timjin
    Fan custom modified
    Logitech MX518
    Saitek Gamers Keyboard
    Its getting old, been upgrading it over the past few years, mainly the ram and the gpu's. Will hold out till some next year before I build another one.
211
Location
Reading PA
This only applies to if you use 32 bit browser. I have been using the 64 bit Internet Explorer 8 and I am yet to have Flash Player work...even the instructions posted. I dont think there is directy support for 64 bit addon for internet explorer 64 bit.
    17" Laptop Screen
47
Location
Just west of Chicago, IL
One would think that Adobe would get it's act together and give us a x64 version of flash. It's been how long now that a lot of us have been strugging with this problem? I'm very frustrated with them.
The supposed fixes do not work properly. If I run my system in x32, certain applications will not run or the OS gets twitchy and unstable and the brower (IE7) gets goofy and closes all open net windows. I'm scared to death to d/l and install IE8, too. I know it's not going to fix the flash problem.
I really think my next machine is going to be a Mac. I've been struggling with M$ problems since DOS (which I actually perferred over windows).
Sorry I just needed to rant because I just had to restart my system do to flash error.
    HP Pavilion Elite M9160f
    Core 2 quad Q6700 2.66 GHz
    4096 MB PC2-5300 DDR2 SDRAM
    NVIDIA GeForce 8600 GT graphics
    720 GB (2x360 GB) 7200 RPM Sata hard drive
    465 GB external personal media drive
    and lots more including 8 speaker configurable sound system
Airbot
2,010
Says right in the link that was provided...
Adobe Flash Player is not supported for playback in a 64-bit browser. However, you can run Flash Player in a 32-bit browser running on a 64-bit operating system.
So, that would be no, there is no flash for 64 bit browsers in Windows. They only have one for 64 bit browsers in Linux.
They claim they will finally have 64 bit support in a version sometime after flash 10.1, which is in the Beta stage right now.
    Airbot 2.0
    EVGA Nvidia GTX 480 -Fermi
    ASUS Xonar D2X
    1920x1080@60hz
    1 OCZ Vertex2 180GB SSD
    Pioneer DVD Burner DVR-S18M
    Corsair HX1000W
    Cooler Master HAF 932
    Logitech Wireless MK700
    Windows 7
    W.E.I final score= 7.7
    Windows Vista=5.9
