adobe flash player
S
silly billy
adobe flash player i have sucessfully installed it but when its needed i keep
having to return to there site and download and then cant use it some s
silly billy,
You state that you have "installed" Adobe Flash Player. Did you
actually install it or did you simply download and run it when prompted by a
website?
You must uninstall any Adobe Flash Player entries from your system
using the Adobe Flash Uninstaller. You must then uninstall any leftover Adobe
Installers from your system. You should then reboot your system and check for
any Adobe software stragglers.
Once you have completely removed anything and everything Adobe from
your system you can go to Adobe's website and install it. Once installed it
will not be removed from your system.
Have a nice day.
C.B.
Brink
Staff member
mvp
Hi Billy,
Use the Adobe Flash Player uninstaller to completely remove the Adobe Flash Player from your computer. Restart the computer.
How to uninstall the Adobe Flash Player plug-in and ActiveX control
Next, install the Adobe Flash Player again directly from Adobe.
http://www.adobe.com/shockwave/download/download.cgi?P1_Prod_Version=ShockwaveFlash&promoid=BIOW
It should work now.
  • Show second system?
    Yes
    Operating System
    ASUS Maximus X Code Z370
    Integrated
    3 x 27" Asus VE278Q
    1920x1080
    250GB Samsung 960 EVO M.2,
    256GB OCZ Vector,
    6TB WD Black WD6001FZWX
    Corsair Air 740
    Logitech MX Master
    Creative F200 webcam,
    Linksys EA9500 router,
    Arris SB6190 cable modem,
    APC SMART-UPS RT 1000 XL,
    Lumia 1520 phone
