advice on system config please
K
KRK
Hello,
In my system configuration file there are 3 startup options, 'normal
startup' , ' diagnostic startup' , and 'selective startup '.
I have 'selective startup' ticked. I cannot remember fiddling with this
file, but might have done and if so I cannot recall why!
My pc seems ok, should I switch back to the 1st option ?
Advice please
Thanks
KK
tom982
٩(͡๏̯͡๏)۶
My laptop also has a selective start up.
Having a selective startup isn't a problem. It is simply not running all of your startup entries at the startup, which should be improving the speed of your computer.
I would advise against modifying the startup procedure unless you have the knowledge of what you are doing.
    Build #1
    Intel Core i7 3770K @4.4GHz
    ASUS P8Z77-V PRO
    Integrated on motherboard
    23" LG LCD/LED IPS
    1920*1080
    Samsung EVO 128GB SSD
    Seagate Barracuda 2TB 7200rpm
    NZXT Phantom 410
