AERO minimum requirements.
R
Retired
What are the minimum hardware requirements for Aero? My system has 512 MB of
RAM, is running at 950 MHZ, and has 65 MB of onboard memory on my graphics
card. Thank you.
I
Iuvenalis
"Retired" <retired@my.hom> wrote in message
news:egBPTePiHHA.4704@TK2MSFTNGP06.phx.gbl...
> of RAM, is running at 950 MHZ, and has 65 MB of onboard memory on my
> graphics card. Thank you.
I enabled it on an old laptop with 512mb ram & it ran dog slow.
That was with 128mb of video memory.
M
Mike Brannigan
Windows Vista Premium Ready PCs
Some Windows Vista Capable PCs have been designated Premium Ready. These PCs
will provide an even better Windows Vista experience, including the Windows
Aero user experience.
see Premium spec at
http://www.microsoft.com/windows/products/windowsvista/buyorupgrade/capable.mspx
You do not meet it.
Mike Brannigan
T
Top Poster
"Mike Brannigan" <Mike.Brannigan@localhost> wrote in message
news:BB7F88B1-14D0-43DB-9E23-08A61D1FC36F@microsoft.com...
> PCs will provide an even better Windows Vista experience, including the
> Windows Aero user experience.
> see Premium spec at
> You do not meet it.
> Mike Brannigan
He asked for the minimum spec?
A Windows Vista Capable PC includes at least:
a.. A modern processor (at least 800MHz¹).
b.. 512 MB of system memory.
c.. A graphics processor that is DirectX 9 capable.
R
Robert Firth
You need 64mb dedicated graphics memory or more (128+ mb recommended),
DirectX9
Pixel Shader 2.0 support
I think that is about it for the graphics card.
Robert Firth
http://www.winvistainfo.org
"Top Poster" <thatsme!> wrote in message
news:cIGdnTRwNLFoxq_bnZ2dnUVZ8sKlnZ2d@bt.com...
>>> MB of RAM, is running at 950 MHZ, and has 65 MB of onboard memory on my
>> see Premium spec at
>> You do not meet it.
>> Mike Brannigan
R
Retired
Thanks Everyone. The reason I asked is because all of the features of Vista
(I installed Vista Home Premium) work except for AERO.
L
Lang Murphy
I see others have posted links to Aero minimum reqs.. so...
Assuming you have a WDDM video driver...
I had one of the Vista betas installed on a laptop with 512MB RAM and 64MB
Video RAM (I think it was 32MB dedicated and 32MB shared system RAM) and I
got Aero working with a combo of reg hacks and cmd line commands...
(I'd make note of the current settings before changing them in case
something blows up. You could export the DWM reg key as a backup. And maybe
create a system restore point before trying this... just in case...)
1) Ensure that you have the following registry values set to:
[HKEY_CURRENT_USER\Software\Microsoft\Windows\DWM]
"Composition"=dword:00000001
"CompositionPolicy"=dword:00000002
"ColorizationOpaqueBlend"=dword:00000001
2) Restart DWM by opening a command prompt with administrative privileges:
Type 'net stop uxsms'
Then 'net start uxsms'
To be honest, though... that's a borderline config for Vista. Especially the
512MB's RAM. And is the "onboard" video memory "dedicated" or "system
shared?" If the latter, that's taking away from your 512MB of system RAM.
Good luck!
Lang
R
Retired
#8
"Lang Murphy" <lang_murphy@hotmail.com> wrote in message
news:8FB9335C-CAD7-4343-9E78-780220ECFC32@microsoft.com...
> maybe create a system restore point before trying this... just in case...)
> the 512MB's RAM. And is the "onboard" video memory "dedicated" or "system
> Good luck!
> Lang
Thanks for the tips.
By the way, as I said in my original post, my graphics card has onboard
memory. This means that it is memory that is dedicated to graphics tasks and
is not system shared memory. If the graphics card had no onboard memory,
then the graphics tasks would need to borrow memory from the regular RAM
chips, i.e., be system shared.
K
keepout@yahoo.com.invalid
#9
There is a page at M$ That tells you all you need to know, assuming you worked
for M$ in the design of Aero.
Something that might help. I show aero in my personalized settings.
right click the desktop -> personalize -> window color & appearance -> see if
you have windows aero in the theme selector. select it. reboot.
If you still don't have it, maybe you're using a TV on your machine ? Aero
won't run with my TV on. But turn the TV off, it works.
but it toggles back and forth between aero and basic if you select aero.
more pix @ http://members.toast.net/cbminfo/index.html
B
Bob Eyster
#10
Think the min for the Graphic card is 128MB and should have 1GB of RAM on
the PC/Laptop. Not required but recommended
Bob Eyster
MS Windows Vista Home Premium
news:eb47eXaiHHA.1624@TK2MSFTNGP06.phx.gbl...
>> 64MB Video RAM (I think it was 32MB dedicated and 32MB shared system RAM)
>> and I got Aero working with a combo of reg hacks and cmd line commands...
>> case...)
>> privileges:
>> Good luck!
>> Lang
> and is not system shared memory. If the graphics card had no onboard
> memory, then the graphics tasks would need to borrow memory from the
> regular RAM chips, i.e., be system shared.
L
Lang Murphy
#11
>> case...)
>> privileges:
>> Good luck!
>> Lang
Well... yeah, wasn't sure what you had and wanted to be clear... if you look
at the video RAM numbers in Vista there's no "onboard" video RAM qualifier.
(Just Dedicated Video Memory, System Video Memory, and Shared System
Memory.) So... I was just making sure. No biggie.
Lang
