Ahhh how to
Avo
Turn flip 3d back on?
I tried this-
1) Click on the Windows logo at the lower left corner
2) Select Control Panel, and then select Personalization
3) Click on “Window Color and Appearance”
4) If you then see a row of 8 colors, you need to click on the last link, “Open classic appearance properties for more color options”
5) In the “Appearance Settings” window, under “Color Scheme,” select “Windows Aero”
6) Click on “OK”
7) Windows will then update the display properties of, well, everything.
8 ) If you’ve got a “Flip and Flip” icon in the Quick Launch area of the taskbar at the bottom of your screen, next to the Windows icon, click on it to see a neat sideways 3-D representation of all of your open windows. OR, hold down the “Start-Tab” keys in order (where Start is the key with the Windows logo) and then (still holding the Start key), hit the Tab key to 3-D’ly scroll through each of the open windows. Uber-cool.
But for some reason the the icon in the taskbar is only giving me the option to "Show desktop" not flip and flip which I did have before!
How do I get it back? I want to scroll through all my open windows without using 'start-tab' keys.
Thanks
Brink
Staff member
mvp
    3 x 27" Asus VE278Q
    1920x1080
    1TB Samsung 970 EVO Plus M.2,
    250GB Samsung 960 EVO M.2,
    6TB WD Black WD6001FZWX
    Logitech MX Master
    Linksys EA9500 router,
    Arris SB8200 cable modem,
    Lumia 1520 phone
Avo
Thanks for the reply and the link, very handy indeed.
However!, I didn't have to use it!!! After posting yesterday I turned the PC off, I have just turned it back on to to see if there were any replies to my question and hey presto the flip icon is in my taskbar! Guess it just needed a reboot to sort itself out after turning the aero theme back on.
Thanks again ;)
Brink
Staff member
mvp
Avo,
I'm glad to hear that it sorted itself out for you. :geek:
    3 x 27" Asus VE278Q
    1920x1080
    Logitech MX Master
    Lumia 1520 phone
C
Carl
You are a genius, thanks a million I have been screwing with this for a
month, again tks. As Always Carl
> I tried this-
> 3) Click on “Window Color and Appearanceâ€
> link, “Open classic appearance properties for more color optionsâ€
> 5) In the “Appearance Settings†window, under “Color Scheme,†select
> “Windows Aeroâ€
> 6) Click on “OKâ€
> everything.
> 8 ) If you’ve got a “Flip and Flip†icon in the Quick Launch area of
> open windows. OR, hold down the “Start-Tab†keys in order (where Start
> Uber-cool.
> Thanks
> Avo
